10 members (Hamwich, Willowgreen320, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 254 guests, and 47 robots.
+8Rich 91
Luddite 50
Posts837,969
#474321 27/09/17 04:32 PM
V
vww1l Offline OP
V
Hi all
What air filter do you recommend for my M3W? I would like to increase the power and looks of the engine.
Cheers
Jon
2012 M3W
2011 Aero Coupe
2018 Aero GT 8/8
Jon
Originally Posted By vww1l
Hi all
Cheers
Jon
As I understand it, the stock drivetrain is outlet not inlet constrained. Did you already change the exhaust?
Meanwhile check out https://view.publitas.com/ss-cycle/dealer-catalog/page/454-455
Hi all
You need to be looking at the exhaust side of things more than the air filter. There are offerings from MMC (Stage 1 system), G56 and Krazy Horse at the moment, plus one or two others that involve a bit more fabrication.
+1
I had the MMC stage 1 fitted in 2 stages – first the air filter which made no perceptible difference and I still had pinking at high revs.
Adding the exhausts transformed the car with smoother running, freer revving and no pinking.
Red Leader drive
Hi all
Try cutting a 38mm hole in the front baffle on the standard exhausts first. You will need a hole saw & 2 x 30cm extensions to reach them. This will make the exhaust a bit more free flowing & a bit noisier but not a affect getting an MOT. Little cost & may be enough for you.
Tim
I fitted a Kylurakyn (?) Stealth intake with a K&N filer to my M3W
I imported it from a HD dealer in the USA as at that time you could not get the full conversion kit needed for UK.
It did make a difference IMO
I think Uncle Melvyn Rutter sells the kit now.
Neil
+1 Neil got mine from Williams Morgan though! and drilled out the first baffle.....
V
vww1l Offline OP
V
Thanks all. I am close to Williams Morgan but in face I live in Worcester so closer to MMC. Its going to them for a couple upgrades so will ask the questions as to if its had the stage 1 kit. I have noticed it does pink when giving it the beans. Sounds like stones being thrown onto the cowlings. Is this pinking harmful and does it need sorting?
2012 M3W
2011 Aero Coupe
2018 Aero GT 8/8
Jon
Your pinking could also the rev limiter cutting in! But Pinking is not good either,! sherlock
