1 members (M3WMW),
150
41
Topics49,911
Posts838,152
Posts: 22 |
I bought a Morgan a few months ago and have just torn a second pair of trousers while getting in and out of it. I’m not particularly fat, although I’m 5’11” and 90 Kgs. People are bigger now than they were in the 1930s or 1940s. Wouldn’t an extra cm or two in the car’s dimensions make it easier to own and live with a Morgan?
In addition Morgan owners are older and less flexible than they once were.
Increasing the size would also bring Morgans closer to modern cars in size.
Comments please.
Dreamon. 1987 4/4 2-seater 1.6 CVH
Posts: 37,489 Likes: 993
Posts: 37,489 Likes: 993 |
Did you not get these with the car then ?
Posts: 22 |
Lederhosen! Jawohl Mein Herr.
Seriously two back pockets torn and I’m told my backside isn’t disproportionately large. I catch the pocket in the door lock mechanism on the body tub. Also I’m 64 and getting less flexible every day.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
What steering wheel do you have on the Mog ? An offset wheel might help to give you a bit more space Also the Librand door stays will keep the door open wide while you egress Then I would recommend stronger trousers
Is it a short or long door car you have ? There is quite a difference I am of similar proportions to you and have never torn trousers though and I'm 66 but reasonably flexible and that's over 13 years of Morgan's.
Posts: 3,829 Likes: 69
Posts: 3,829 Likes: 69 |
I always drive naked to avoid the problem. Mind you, setting the handbrake cannbe confusing.......... Nick
I always drive naked to avoid the problem. Mind you, setting the handbrake cannbe confusing.......... Nick As long as it’s only the handbrake that flies off
Posts: 2,539 |
I always drive naked to avoid the problem. Mind you, setting the handbrake cannbe confusing.......... Nick +1
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
On the subject of trousers and handbrakes; at the start of the infamous 1955 Le Mans, Juan Manuel Fangio was delayed at the start, having jumped into the car, he proceeded to get the leg of his trousers stuck over the handbrake!
Bud 4/4 "Stanley"
Posts: 3,482 Likes: 42
Posts: 3,482 Likes: 42 |
Jaysus, Eamon -- I thought I showed you how to get in and out properly!!!!!!!
