2 members (Ian B, ScotiaSteve), 315 guests, and 106 robots.
+8Rich 84
Topics49,860
Posts837,484
Page 97 of 108 1 2 95 96 97 98 99 107 108
Draggin Offline OP
To be fair even the thousand-mile checklist says it can be changed if the customer asks for it to be changed I guess I wasn't specific. One more piece of maintenance for me to do on a toy before the snow flies.
kirkusblog.com
1952 Ford 8N
Took mine out yesterday pm, almost springlike weather. But that could almost be it for the year. Back to fettling other toys then.
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Draggin Offline OP
I know what you mean Glenn, the temps are dropping here, too.
Yesterday I made a list of all the toys that need to be touched before winter, and its daunting!
kirkusblog.com
1952 Ford 8N
But you would be dead bored without them!
'16 M3W
'44 Willys Jeep
'16 Westfield 11
Draggin Offline OP
Does anyone else have a squealing noise when they first start their cars when cold? It goes away upon pushing the clutch in. Only happens during the first cold start. If I have a clutch release bearing that is failing I would rather get it replaced under warranty.
kirkusblog.com
1952 Ford 8N
Not sure if you have to have the clutch pressed to start the M3W or not. But if so, as soon as you start it in neutral and take your foot off the clutch, does the squeal go away?
The throwout bearing would only be spinning if the clutch were to pressed.
Dan
Draggin Offline OP
no I leave the clutch in to start, car in neutral.
the squeal goes away when I press the clutch in. and also goes away when the car warms up.
kirkusblog.com
1952 Ford 8N
That's weird.
If your foot is OFF the pedal, the throwout bearing should not be in contact with the pressure plate.
Obviously it's related to the clutch in some way, but it's backasswards to what you would think it should do if it's bad.
Dan
Draggin Offline OP
Agreed Dan!
kirkusblog.com
1952 Ford 8N
Draggin Offline OP
kirkusblog.com
1952 Ford 8N
