Posts838,014
Posts: 87 Likes: 1
Posts: 87 Likes: 1 |
Need some advice about replacing Std 14inch wheel with a Mota Lita 15 inch. Is it a good or bad idea?
+4 Jaguar Lazuli Blue - MO6 4 MOG, Morgan Clubsport. Laser Stratos (sadly sold)
Posts: 208 |
Yep you'll turn easily at low speed or in city but you'll get less space for the legs ...
Posts: 2,190 |
Need some advice about replacing Std 14inch wheel with a Mota Lita 15 inch. Is it a good or bad idea? I've got a more mixed view: FOR: Probably a bit easier at low speeds but again, if you go for a 'thin rim' as opposed to a thicker one, this can mean that despite the bigger diameter the steering doesn't actually feel any different AGAINST: Decreased room between wheel and thighs There is also the issue of how it looks; eg do you want a wood rim, leather or 'bluemels' type finish. Have you 'widened the search a bit' and considered an offset spoke wheel?
GLLHG
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Can I just add that having lubricated my rack it has transformed the feel. It's much lighter. But it's a tricky job with limited access.
Posts: 87 Likes: 1
I would go for a std leather rim, seems to be plenty of space as its a 4 seater? Does that make sense?
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
I have an offset Mota Lita 15 inch wheel. It ives good leg clearance but also allows you the leverage at low speeds.
Posts: 203 |
Hmmm... I just browsed the Motolita website, but could not locate any information on the above mentioned "offset" wheels... ... any pointers?
4/4 Sport 'Sports Red' (12/2009)
Greetings from Switzerland Wilhelm
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
Ring Steve Simmonds (Ads in Miscellany) -- That's where I got mine
Posts: 2,190 |
Ah! the swift and convoluted departure from Newtown post- purchase but pre the ferry! Cheers Robbie regards, G
GLLHG
Not this one G -- I had an offset one from Steve on the previous car -- I opted for one of Steve's new spoked ones for Tafie - That and the door pockets led to the departure you mention!!
Cheers!
