3 members (MJF, Jon G4LJW, RedThree), 366 guests, and 31 robots.
+8Rich 95
John V6 52
Posts838,003
rockabilly john
#47704 22/07/10 02:39 PM
WOX9 Offline OP
Need some advice about replacing Std 14inch wheel with a Mota Lita 15 inch. Is it a good or bad idea?
+4 Jaguar Lazuli Blue - MO6 4 MOG, Morgan Clubsport.
Laser Stratos (sadly sold)
Yep you'll turn easily at low speed or in city but you'll get less space for the legs ...
South Wales Correspondent
I've got a more mixed view:
FOR:
Probably a bit easier at low speeds but again, if you go for a 'thin rim' as opposed to a thicker one, this can mean that despite the bigger diameter the steering doesn't actually feel any different
AGAINST:
Decreased room between wheel and thighs
There is also the issue of how it looks; eg do you want a wood rim, leather or 'bluemels' type finish.
Have you 'widened the search a bit' and considered an offset spoke wheel?
GLLHG
Can I just add that having lubricated my rack it has transformed the feel. It's much lighter. But it's a tricky job with limited access.
WOX9 Offline OP
I would go for a std leather rim, seems to be plenty of space as its a 4 seater? Does that make sense?
I have an offset Mota Lita 15 inch wheel.
It ives good leg clearance but also allows you the leverage at low speeds.
Hmmm... I just browsed the Motolita website, but could not locate any information on the above mentioned "offset" wheels...
... any pointers?
4/4 Sport 'Sports Red' (12/2009)
Greetings from Switzerland
Wilhelm
Ring Steve Simmonds (Ads in Miscellany) -- That's where I got mine
Robbie
2021 Plus Four -- Helga
211-WX-1433
Ah! the swift and convoluted departure from Newtown post- purchase but pre the ferry!
Cheers Robbie
regards,
GLLHG
Not this one G -- I had an offset one from Steve on the previous car -- I opted for one of Steve's new spoked ones for Tafie - That and the door pockets led to the departure you mention!!
Cheers!
Robbie
211-WX-1433
