7 members (AlyMatt, piquet, +8Rich, BobtheTrain, TBM, GrumpyPa, PaulV), 247 guests, and 49 robots.
+8Rich 95
John V6 52
Posts838,002
rockabilly john
#477904 20/10/17 03:30 PM
Has anyone worked on a better ride for a Roadster
I changed the front shocks to AVO setting 6
Still rough ride
Question should I do the back shocks and if so what setting
Allan 2005 Roadster
My 2005 roadster had those nylon front bushings which used to seize as they warmed up. Once I changed to bronze things were fine.....could that be affecting yours?
Nick
Mine are upgraded all round. The ride is fine.
This might help
http://www.gomog.com/allmorgan/shocks.html
I still have the plastic Devol bushes but they work well
Thanks John the mirrors worked out fine
What do you think changing the back shocks
Allan 2005 Roadster
How often do you grease the King Pins
Dave
98 +8 Corsa Red
74 MGB Red
Thank you Nick
Allan 2005 Roadster
I would change the rear shocks especially if they are Mr Morgan's cheap one but before you do that get some motorcycle chain lube & spray up the rear springs. I do that annually.
Will do
How about front and back setting for shocks
Allan 2005 Roadster
How is the ride of the new Morgans
Allan 2005 Roadster
Not sure yours is only 1 tear older than mine.
I have my Avos at the GoMog settings
