Posts838,005
Posts: 23 |
Has anyone worked on a better ride for a Roadster I changed the front shocks to AVO setting 6 Still rough ride Question should I do the back shocks and if so what setting
Allan 2005 Roadster
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
My 2005 roadster had those nylon front bushings which used to seize as they warmed up. Once I changed to bronze things were fine.....could that be affecting yours? Nick
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Mine are upgraded all round. The ride is fine. This might help http://www.gomog.com/allmorgan/shocks.htmlI still have the plastic Devol bushes but they work well
Posts: 23 |
Thanks John the mirrors worked out fine What do you think changing the back shocks
Allan 2005 Roadster
Posts: 463 |
How often do you grease the King Pins
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 23 |
Allan 2005 Roadster
I would change the rear shocks especially if they are Mr Morgan's cheap one but before you do that get some motorcycle chain lube & spray up the rear springs. I do that annually.
Posts: 23 |
Will do How about front and back setting for shocks
Allan 2005 Roadster
Posts: 23 |
How is the ride of the new Morgans
Allan 2005 Roadster
Not sure yours is only 1 tear older than mine. I have my Avos at the GoMog settings
