7 members (gomog, GLLOQ, John V6, Barkbark, JohnHarris, BLUE+4, AlyMatt),
329
94
Topics49,877
Posts837,727
Posts: 314 Likes: 3
Posts: 314 Likes: 3 |
To design a custom made dashboard (mainly arrangement of instruments) I would need a drawing of the current classic dashboard (the outer shape would be sufficient).
Michael 2018 Plus 4 Sport
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
Just use your existing one as a template, it's not a big job
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
Hi Michael, I’ve got a current ash dash left hand drive hanging on my den wall. I will gladly copy the outline onto a piece of paper if it helps and post to you. Regards from Wales.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
To design a custom made dashboard (mainly arrangement of instruments) I would need a drawing of the current classic dashboard (the outer shape would be sufficient). I'm not sure if it would be of any use but I have a outline drawing with dimensions of a 1982 4/4 dashboard that I could sent you as a PDF
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
To design a custom made dashboard (mainly arrangement of instruments) I would need a drawing of the current classic dashboard (the outer shape would be sufficient). Do you have a LHD or RHD car/dashboard?
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
To design a custom made dashboard (mainly arrangement of instruments) I would need a drawing of the current classic dashboard (the outer shape would be sufficient). Do you have a LHD or RHD car/dashboard? Just turn the template over
Richard 1976 4/4 4 Seater
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
To design a custom made dashboard (mainly arrangement of instruments) I would need a drawing of the current classic dashboard (the outer shape would be sufficient). Do you have a LHD or RHD car/dashboard? Just turn the template over Actually to do a perfect job it may not be quite so easy. As we all know every Morgan is different and the shape of the top of the dash, under the leather roll, and the point above the door opening can be a variable, all be it slight. I would start with a piece of plywood cut at least 5mm wider on each side and with the bottom corners 5mm down. I would then trim the sides and the curve under the windscreen pillars until it fitted up well under the scuttle then trim the bottom left and right corners. The next step would be to put the board in place and sit in the car and then mark the point which is visibly in the centre of the steering wheel from the driver's point of view. Note that the exact position of the steering wheel is another Morgan variable and has not been constant over the years. The visual centre of the dash behind the steering wheel is not exactly in line with the car because the steering wheel is slightly offset from the drivers seat. If you don't get this point correct any instruments or warning lights that should be visually central behind the wheel will appear to be a few millimetres to one side when viewed from the driver's position. Difficult to explain. I hope I have made it understandable.
I have this original factory walnut dash from the pre-GDI Plus 4 if it is any help. Borghi has dashboards for just about every model available. http://www.morganautomobili.it/allestimenti.htmlYou need to scroll down to find the GDI dashboards.
Posts: 314 Likes: 3
Thanks to all of you for the valuable inputs The dashboard is intended to be for a new Plus 4 LHD (production start scheduled for week 3/2018). As the original arrangement of the instruments for a LHD IMHO is not perfect, I decided to go for a custom made dash. @Gambalunga: thanks especially for the hint regarding the offset! I intended to have the dash produced in parallel to fit it right after the arrival of the car. But it seems worth waiting to have the original as a template. Difficult decision
This is the Borghi dash for the Plus 4 GDI (current model) You can have it in a wide variety of timber finishes and have a Motolita steering wheel re-finished in matching timber. Good excuse for a holiday in Italy  The GDI dash provided a good deal of the inspiration for my new dash below. New dashboard in elm with magnolia faced instruments at Borghi's ready to install. New Dashboard installed Driver's view. Passenger's view.
