0 members (), 296 guests, and 72 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
#482303 11/11/17 08:06 PM
MOR404 Offline OP
I wish to introduce myself as a new owner of a Morgan 4 1980. I have tried to remove my dashboard after removing steering wheel, shroud behind boss, screws holding shelf for glove compartment and the wood screws at the side tips of dash. It still cannot get off at the top. Are there any screws holding it at the top?
It sounds as if you have removed all of the fixing elements, so it maybe the problem of sticksion, if that's the case just give it a firm yank
PS I think you maybe loitering in the wrong forum area
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
There may be one or two screws high up under the scuttle.
That was my experience as well
I just had to keep plucking up the courage to give it a firmer yank each time after a few deep breaths and double checking that I had removed every fastening
It came free eventually without any damage but it was quite a firm yank
On the Imperial Sticksion Yank scale of 1 to 12, it was a 10
On top , in the middle....mostly
Stefan
MOR404 Offline OP
Thank you all for your hints. As regards loitering in the wrong forum area, can you suggest which is the right one for future
You posted your question in "Vehicle Talk - Non-Morgan".
As it's a question about maintenance on a trad Morgan, you might have been better off posting it in "Traditional Morgans" or ideally "Maintenance and Servicing". It makes it easier for others to spot what the post might be about and respond to it. Not everyone reads every post in every forum.
HTH
MOR404 Offline OP
Thank you
