0 members (), 287 guests, and 55 robots.
Topics49,860
Posts837,486
Jonny72
#484399 21/11/17 09:56 PM
I just received my Morgan 3 wheeler yesterday. I am 6'3 and need to adjust the foot pedals back as far as they can go. The owners manual says to have a dealership do it. I am in Utah and a long ways from a dealer. I have searched this forum but cannot find good information on how to adjust them. Can anyone offer me some advice on how to move them back?
Thanks
Remove hood find the inspection hatch (6x 8mm head bolts to remove) go under car remove 13mm lock nuts remove grommets blocking the holes you require! go up top grab the pedals through the afore mentioned hatch! lift clear of holes move to where you need locate into hole's go under refit all lock nuts and grommets into empty hole's,replace inspection hatch ,hood test drive and smile drive
Welcome to TM enjoy your miles, check this thread out.
http://www.talkmorgan.com/ubbthreads.php/topics/447943/24
Did mine. Super easy once you pop the access panel.
kirkusblog.com
1952 Ford 8N
What year is the car? The 2012 and 2013 models have an asymmetric plate which is great for right hand drive but cannot move to the far forward position on the left hand drive models.
You will also notice that the bolts used have Loktite on them. Get more and use it wisely. Carry a small container with you on your travels along with duct tape and a minimum collection of hand tools.
You will be grateful that you did...
It’s a 2016, Thanks so much for the advice. I will adjust them first thing in the morning.
Also worth considering a steering wheel spacer. Krazy Horse in UK make them. My 6’4” son appreciated that mod.
Tim
With my new chassis there are no alternative mounting holes in the floor guess they just drilled same as old & saved 10 pence. If KH dont have wheel spacer try Revolutions, they made one for me & had a batch made.
Tim
+1 on the steering wheel spacer - made a huge difference to me.
Red Leader drive
Can you send me links to the company’s that sell the spacers?
