7 members (MATTMOG, deano, Julian BB, Alan Patterson, Image, Roady, Clipper),
321
58
Topics49,859
Posts837,511
Posts: 37,418 Likes: 978
Posts: 37,418 Likes: 978 |
Here is the Krazy Horse one. http://www.krazyhorse.co.uk/
Posts: 8,675 Likes: 411
Posts: 8,675 Likes: 411 |
Can you send me links to the company’s that sell the spacers? B-G racing spacers are available in a variety of depths from Demon Tweaks and likely much cheaper than Morgan dealer sources.  I used a 25mm one. Click above for source. You will then need appropriate longer length M6 button head screws.
Posts: 14 |
Thanks for all the advice. I only had one more set of holes to move it back. But that extra two inches made all the difference in the world. Might not even need the steering wheel spacers now.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
You can test the benefit of a steering wheel spacer as the quick release has 2 stages.
If you carefully release the wheel and pull it about 1/2" towards you it will engage on a second lock. It's OK to drive it carefully like this and you'll get a feel for whether the extra legroom is a help or not.
Red Leader
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
If you carefully release the wheel and pull it about 1/2" towards you it will engage on a second lock. It's OK to drive it carefully like this and you'll get a feel for whether the extra legroom is a help or not. I would not drive it without the wheel properly latched in it's forward position, other than back and forth in the garage perhaps. I've heard tell of two folks who were "surprised" when the wheel came off in their hands while going down the road when not latched correctly. No accidents resulted, but a change of underwear apparently was called for.
Posts: 1,461 |
Use of the term "foot pedal" is a punishable offence.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
Use of the term "foot pedal" is a punishable offence.  ISWYDT
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
As a teaching dental technician I knew used to say, “The students need manual dexterity with there hands...” Tim
Posts: 14 |
I bought the B-G wheel spacer and realized it only fits the standard steering wheel. I have the Brooklands addition steering wheel which as 4 bolts instead of 3. Anyone one know of any sources that sell a steering wheel spacer for the brooklands steering wheel?
Thanks,
Jud
Posts: 874 Likes: 157
Posts: 874 Likes: 157 |
I added this piece of karting to stall heels
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
