1 members (+8Rich),
360
50
Topics49,860
Posts837,485
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
I agree with JTL - much better lines without them. When I specced out my Plus 4 I asked for no tread rubbers - and I'm very pleased with the result. No discount for NOT having them, though. Same for me. Can't see the point of 'em. Nick
Posts: 853 |
I agree with JTL - much better lines without them. When I specced out my Plus 4 I asked for no tread rubbers - and I'm very pleased with the result. No discount for NOT having them, though. Same for me. Can't see the point of 'em. Nick Sorry to disagree but I think they add to the classic appearance of the car
Ken A. Plus 4 2009 Centenary Metallic Red Plus 8 1994 Dark Green (prev) Honda CB100 The Big One
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
I like the look of two strips each side, but didn't have them on the Plus 4.
I would avoid pop rivets, just because I find them difficult to drill out without drifting off-centre, and the aluminium formers are thin.
I think the best option for a refit is double sided tape, with plastic pegs to locate properly. A length of plastic rod could be used - heating the top of each short length to create 'rivets'.
Posts: 1,036 |
I would avoid pop rivets, just because I find them difficult to drill out without drifting off-centre, and the aluminium formers are thin. Seriously Dave? You have difficulty drilling the top of an aliminium pop rivet without tracking off centre when there's a pilot hole through the rivet? Personally, I would avoid double sided tape as should you wish to remove the running strip base from the wing, one risks damage to the paintwork. I can understand that pop rivets might offend the purist but they are easy to use, cheap, easy to remove and out of sight so unlikely to invite any adverse comment from the purist.
Posts: 5,587 |
I agree with JTL - much better lines without them. When I specced out my Plus 4 I asked for no tread rubbers - and I'm very pleased with the result. No discount for NOT having them, though. Same for me. Can't see the point of 'em. Nick I had them installed due to folks feet damaging the paintwork.
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
I used aluminium rivenuts with stainless countersunk screws (so no nuts underneath). Single sided SA neoprene applied to the strips to prevent water getting between the strips and the running board. Easy to remove when required.
1993 T16 +4 Lancia Blue.
Posts: 1,036 |
That's a neat solution JBK - a sort of sophisticated pop-rivet approach!
I've never really got on with pop rivets. The tricky ones are those where the centre rod has snapped off above the rivet head and can't be persuaded back down. So I use alternatives where I might need to dismantle.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
You are aware of plastic pop rivets I take it? absolutely no battery action or corrosion issues.
