8 members (IcePack, JohnHarris, DickJ, deano, SailingTom2, Alistair, High Hamster, BobJ),
235
139
Goodwood
Topics49,931
Posts838,505
Posts: 381 |
Thank you, very interesting but photos not found?
Regards 2005 PLUS 4
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
Dave’s "How To" Consolidated List as at April 2020
On the earlier posts, you have to scroll right down to the end to see the images. I had to repost the whole series after the Photobucket debacle a few years ago.
INDEX...….I'm not smart enough to be able to put the links here in this consolidated list without spending a lot of time...……. Most of the links are embedded earlier in this post anyway, except for the final few, which you should be able to find.
07/01/2009 Dave's Diary of 'Making it Better' 07/01/2009 Roadster Relays 10/01/2009 Badges without Bars with Overriders 17/01/2009 Dave's Diary of 'Making it Better' Chapter 2 01/02/2009 Dave's Diary of 'Making it Better' - Chapter 3 13/02/2009 Roadster - Steering Feel & Stub Axles 14/02/2009 Where to mount a Rally Plaque..... 28/02/2009 Mainly about exhaust mountings 09/03/2009 Dave's Diary - about a front spoiler! 12/03/2009 Dave's Diary - The Story of the Spoiler 22/03/2009 Spare Wheel Well 02/05/2009 Annoying creak from windscreen frame. 29/05/2009 Roadster Series One - Servicing. 07/06/2009 Insulating metal garage doors 07/06/2009 Spare Wheel Security on Traditionals 11/06/2009 Roadster Series One - Servicing (underside) 14/06/2009 Transmission oils for traditionals 23/06/2009 Tax Disc Holder - quick tip 13/09/2009 Heater Control Knob - Rotary 12/07/2009 Traditional Cars - Indicators & Brake Lamp Switch 01/08/2009 Mainly about 2009 Trads in pictures 26/09/2009 Small coolant leak from radiator - Roadster. 01/10/2009 Dave's Guide to closed cell Neoprene........... 11/10/2009 Perspex Windstop for Traditionals 15/10/2009 Screen Frame & Sidescreen 'Weatherproofing'. 15/10/2009 Series One Roadster drive belts. 18/11/2009 Winter Buddy Half Tonneau 28/11/2009 Series 1 Roadster - Throttle Cable 09/12/2009 Traditionals - next step - underbonnet insulation 23/01/2010 Classic/Traditional Cars - taking the seats out 10/01/2010 Series 1 Roadster Cooling System 13/02/2010 Trads - High level brake light with Luggage 05/03/2010 Series 1 Roadster - Air Filter Box 12/03/2010 Series 1 Roadster - Coil Pack protector 25/03/2010 Dave's 'how to' summary 27/03/2010 Series 1 Roadster - Undertray. 02/04/2010 Classic/Traditional Cars - Bonnet Stays 03/04/2010 Classic/Traditional Cars - insulating fuel lines 20/04/2010 Series 1 Roadster - Sump 02/05/2010 Classic/Traditional Cars - Underwing Protection 21/05/2010 Classic/Traditional Cars - SteeringRackAdjustment 29/05/2010 A morning at Mulfab 12/06/2010 Clutch Fluid - Changing 22/06/2010 Storage:Tonneau Cover,Hood Cover & Sidescreen Bag 04/07/2010 Protection for the Cobra with luggage 07/07/2010 Servicing - Morgan Roadster Series 1 Update 30/08/2010 Dave Sapp's Series 1 Restoration 15/01/2011 Kingpins - Dave's How To. 26/01/2011 Kingpin Supplement - rebound spring protection 05/03/2011 Traditionals - Trolley jack go between. 05/03/2011 The Hose Job - Dave's How To........... 29/03/2011 Dave's new aluminium trolley jack 16/04/2011 Reference - Steering Damper Blades. 22/04/2011 Reflections from MotoLita steering wheel boss. 29/04/2011 Time for a new bench vice......... 07/05/2011 General detailing - visors and door checks. 20/08/2011 Safety Item - rear mounted battery. 14/11/2011 Turrino Wheels 17/01/2012 Atlas Editions Morgan Plus 8 Roadster 10/04/2012 Check your easy up!! 21/05/2012 More on MOT's 31/03/2012 Front indicators 12/06/2013 Seat backrest support alterations. 15/07/2013 Gearbox and rear axle internals - photographs 07/08/2013 Windscreen brackets - A posts - finish. 08/08/2013 Personalised clothing 21/08/2013 The aftermath of Canterbury................. 21/08/2013 Mr Bumble update post Canterbury........ 02/09/2013 September 2013 Service 07/09/2013 Measuring the width............................... 13/09/2013 Mr Bumble blog - early stages 14/09/2013 Seat height 19/09/2013 Bump steer on trad four wheelers 19/09/2013 Talk of wobble............... 21/09/2013 4/4 Anniversary 30/09/2013 Mr Bumble improvements - Phase 2 09/10/2013 Mr Bumble improvements - Phase 3 20/10/2013 Mr Bumble - Phase 4 07/11/2013 Four threaded holes 09/11/2013 Fuses & Relays 12/11/2013 OCD from louvres to............044 27/11/2013 Mr Bumble - the engine cover. 20/12/2013 Bumble - pre-Christmas jobs 31/12/2013 Tool tray replacement.............. 31/12/2013 The factory tool tray - plastic fantastic 07/01/2014 Plus 4 Tyre size? 13/01/2014 Plus 4 Gearknob 13/01/2014 Fitting AVO dampers 18/01/2014 Plus 4 ECU box 02/02/2014 Today what not to do..... 11/02/2014 Bonnet centre buffers 25/02/2014 K&N Filter for Plus 4 15/03/2014 Out and about on 15th March 20/03/2014 2012 4/4 Plus 4 electrickery 02/04/2014 MWS Toblerones 19/04/2014 Cat heat shield 22/05/2014 Post Scotland tweaks 02/06/2014 Hood pivots for traditional studded hood 16/06/2014 Todays jobs preparing for the springs 22/06/2014 How to: Replacing leaf springs 26/09/2014 Heater seal, bulkhead creak, and badge..... 13/10/2014 The Kingpin Job Autumn 2014 14/10/2014 Brake component part numbers from Caparo catalogue 03/11/2014 Plus 4 Service November 2014 16/11/2014 Hub/Stub Axle mounted speed sensor replacement 31/12/2014 Plastic Header Tank Coolant 17/02/2015 Tread Rubbers Maintenance 25/04/2015 MMC 25th April 2015 29/04/2015 More from DaveW (Dash Cam Video) 12/07/2015 More from ToTH2015 (Dash Cam Video) 21/07/2015 Workshop note Wiper blades 11/08/2015 Cleaning Black Wire Wheels 30/08/2015 Workshop note Pre Roadster Service 29/09/2015 Tight access to garage - a solution 04/01/2016 Spare wheel retainers on Trad cars 31/03/2016 Thor Hammers - information 04/07/2016 Plus 4 Improvements - Workshop Notes - Early Days 26/07/2016 Trad cars - Aluminium Tool Tray 08/09/2016 Ford GDI Engine Cover 28/09/2016 Plus 4 Improvements - Workshop Notes 2 - Continuing 18/10/2016 Plus 4 Improvements - Workshop Notes 3 - The Undertray 24/12/2016. Tent poles and tonneau covers 21/02/2017. Front wing retaining brackets 27/06/2017. Battery replacement 14/08/2017. Plus 4 GDI throttle pedal rubber 14/08/2017. Steering rack gaiter 14/08/2017. Roadster front valance 27/08/2017. Images from Run for the Hills 2017 29/08/2017. Misting gauges, 2003-6 dashboard 04/11/2017. Fuel filler hose 20/11/2017. Door lock draught excluder 17/12/2017 Sidescreen Misting 16/06/2018 Roadster S1 Spark Plugs Inspection 18/07/2018 Wolf Performance/BHM Skidplate 21/10/2018 Workshop Note: GDI Immobiliser. 11/11/2018 Workshop Note: Brake Fluid Change 18/11/2018 Workshop Note: GDI Heat Shield & Splashguards 18/11/2018 Workshop Note: Mulfab Steering Bearings 09/12/2018 Workshop Note: GDI Oil Breather 13/12/2018 Workshop Note: Fitting a Panhard Rod, Roadster S1 13/01/2019 Workshop Note. Roadster Brake Upgrade Part 1 18/01/2019 Workshop Note -Steering Damper 12/02/2019 Workshop Note: S1 Roadster Mulfab Brake Upgrade 20/07/2019 Pedal Car Restoration Update 15/08/2019 Plus 4 GDI Aero Racing Exhaust 03/09/2019 Plus 4 Cowl Badge and Splined wheel hub assembly 10/09/2019 Plus 4 GDI Aero Racing Manifold & Exhaust Upgrade 11/09/2019 Plus 4 GDI Cat/Master Cyl Heat Shield 17/11/2019 Windscreen Washer Tubing Under-Dash 13/01/2020 Rear Wheel Cylinders BTR Axle 28/01/2020 2016 Plus 4 Underdash 27/03/2020 Workshop Note - Bump Stop assists 13/04/2020 Renovo Recolourer and Reconditioner
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Just following the posts I think there is a lot points and things for a second book.
Looking forward
Regards
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
