Topics49,851
Posts837,441
Posts: 13 |
Advice wanted please. I'm looking for a good quality outdoor cover for my 2007 Plus 4, 4 seater. I've purchased one but it didn't fit very well -obviously fine for the 2 seater but the rear of my car stuck out and the cover would then lift up at the back in the wind. Can anyone recommend a good quality cover that actually fits a 4 seater properly? Many thanks!
Warren 2007 Plus 4, 4 seater
Posts: 681 |
Posts: 13 |
Thanks Steve - I'll have a read!
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
Posts: 13 |
Posts: 681 |
Pretty much the best protection on the market. Looking at the website I think I would agree with that. If and when I buy a Caterham again (and as it will have to stay outside as the Morgan will continue to reside in the garage) this could be just the job. Website is bookmarked; thanks
Posts: 20 |
Have you considered using a bag for storage? I cannot get my 79' into my small garage so it stays in a zippered bag in the driveway under a shed roof. My original bag from Germany was too small and only lasted two years. The new one in much larger and easier to use and with desiccants in place reduces the rust/corrosion potential.
Posts: 13 |
Thank you - great idea and might be a possibility.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Advice wanted please. I'm looking for a good quality outdoor cover for my 2007 Plus 4, 4 seater. I've purchased one but it didn't fit very well -obviously fine for the 2 seater but the rear of my car stuck out and the cover would then lift up at the back in the wind. Can anyone recommend a good quality cover that actually fits a 4 seater properly? Many thanks! I reckon you are into a "no win" here. There is no such thing as a no-flap cover and when they flat they end up scuffing the car. Whats more they trap moisture and dampness and if anything hasten corrosion. On the other hand Morgans leak so no cover isnt a good option either. Maybe one of those car cocoons that have air pressure keeping the fabric off the car?
Posts: 20 |
The use of zipper bag protection requires rust corrosion/rust prevention by removing moisture from the enclosure as I stated. Additionally an inner soft cover to protect the paint is recommended, forcing air into the enclosure is not required. Sealing out the environment when storing outside is important, but you have to do it correctly. The correct desiccant for moisture removal and even chemical absorbent pads under the motor area make this type of protection work well.
