Morgan Aero 8
2 members (yobtaf, BHV), 305 guests, and 40 robots.
Topics49,860
Posts837,486
Jonny72
Peter J #485759 28/11/17 02:18 PM
I forget that the 4wd systems of most new cars are controlled by electronics, it goes to show that there are so many variables on modern cars that even the engineers can't cover everything when testing.
Be interesting to know if they did indeed alter the torque or another differential setting perhaps..
Aero 8 GTN #11
Peter J #488606 12/12/17 04:59 PM
Smile, it confuses them
I have been tracking the tyres noise on lock as discussed.
On the big Mercedes ML with 4WD etc I have Michelin Latitude all season. In the recent cold snap they have been doing this considerably more. As I reverse onto full lock off the drive it hops as you describe.
On my return with warm tyres I use full lock to come up the drive and with the warm tyres there may be a single small hop but nothing significant.
Coupe has a zero battery.
S2 is SORN so cannot check either of these to match.
Does seem tyre temperature related.
Peter J #488985 14/12/17 06:20 PM
V
V
The Pilot Sport 3 and 4 are IMO one of the best all round, all weather road tyre's out there at the moment. On track they are wonderful, they heat up quickly and can do a few heat cycles before they seem to go off and they kick up enough rain that you feel safe in bad conditions.
The current crop of P Zeros I have found very snappy, quite hard to keep heat in and spinny under high torque applications. They seem to have a lot less role over and therefore contact patch seems to be very fixed even at lower pressures. The Nero isn't too bad but the Corsa and the Rosso... I wouldn't be running down to the stockist any time soon.
If you what the best performing tyre currently on the market the TOYO R888 in the soft compound has to be head and shoulders above the rest. It works in the rain but I would be taking it carefully and mindful of standing water. It wears out quickly but boy o' boy they are fantastic - my Noble used to have difficulty keeping up with French hatchbacks who were running them. They have so much grip, are very forgiving and give you so much confidence.
One thing I would mention is tyre pressures. I have found that it's often more important that the tyre itself. Some tyres are more susceptible to it that others but a difference of a few PSI can really change the whole feel of a car especially if the tyre has a decent profile. In my experience people have been complaining about their tyre performance or that the car feels twitchy/sluggish and a change -/+ in PSI completely changes there opinion.
Experiment with this as it's the only way to understand what your set up and your driving style will best suit. I would argue that this is especially important with something as bespoke as a Morgan. In my aero running PZero Neros I have been using 18psi up front and 20psi on the rear to get a good balance out of mine for my style of driving which is fairly smooth but everyone will be different. I will be changing to pilot sports rather than Toyos next year as I am planning on doing a bit of touring :-)
V70LER #489077 15/12/17 09:20 AM
Very interesting regarding tyre pressures, the dealers recommend 25psi for the Aero's and I thought that was low!
Do they not look a tad flat at 18psi?
Aero 8 GTN #11
Peter J #489081 15/12/17 09:48 AM
I keep the S2 around 25psi and the Coupe slightly higher on the back end with the extra weight.
When I went from the Vredesteins to the MPSS on the S2 it needed a couple of extra pounds or it felt slow.
I will try 18 on the car but worry a lot that the small sidewall and precious Rays AeroMax alloys are at risk at that point.
I am assuming that all temps are slightly warm road use?
Tyre pressures should always be checked cold.
