1 members (RichardV6), 71 guests, and 16 robots.
+8Rich 102
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,511
Peter1062
Page 4 of 5 1 2 3 4 5
DaveW Offline OP
Post Photobucket Reboot from March 2009:
I managed to get half a day to myself, and took the luggage carrier and spare wheel off to see if I could smarten things up a bit. There's not much scope under there. The rear frame 'bonnet catches' have a wire which is supposed to run in a groove in the wood, but on mine is a bit slack. I've held it up by slotting a plastic tube behind the centre rear brakelamp bracket. All I could do was to add some thin neoprene to stop the tyre rubbing on the metal plate and cross timbers. I also blew the metal plate over with some satin black, and added a bit more wax rust proofing. I didn't take a 'before' picture, but here's the result. The neoprene shows up as four triangles, and there's a thin horizontal strip where the inner part of the wheel rests, plus a piece on each of the horizontal timbers. It's as tidy as I can make it for now.
And from October 2009:
Was it really March 09 when I did this.........
Time to add some detail I think. I've been busy tonight.....
First - on the left side cross-member there is the production spec in black marker pen. So mine is R/H - (right hand drive I suppose) - V6 - with over-riders.
Then - tucked up behind the fuel filler tube is the chassis number - it's upside down (not the photo)........
Just right of centre of this photo is the main chassis earth - bolted to the chassis, offside.
Here are the offside connectors:
Nearside:
And tucked away under the rear valance over to the nearside........
More to come..........
DaveW Offline OP
Post Photobucket Reboot from October 2009 continued:..........
This picture is looking down on the rear valance inside the spare wheel well. You can just make out two slotted holes below, and to the right of the fasteners. There are three of these fasteners, (allen headed setscrews with locknuts below) and the next photo shows this better.
With those three fasteners removed, it's now clear what happened. The slotted holes were to allow adjustment, but the panel is very slightly too deep to line up, so I suspect that the compromise to make it fit was to offset the panel slightly to the right to avoid opening up the slotted hole into an over-large inverted T shape.
The effect is that the rear panel is offset slightly to the right, and my observations are that most early Roadsters seem to be the same.........
Here's the nearside gap......immediately below is the offside gap, and you can just tell the difference.
This has been niggling for a year. The remaining fasteners on this panel are four cross-head self-tappers with penny washers which locate vertically upwards into the wood frame.Two are outboard of the over-riders and two are inboard. Tonight I had then all off, and using my pin chuck to mark up, then Dremel drill, I slotted the seven holes and relocated the rear panel centrally. It was one hell of a fiddle, but now I can rest easy
The best part of this exercise though..........is still to come............
DaveW Offline OP
Post Photobucket Reboot from October 2009 Continued:
Do you know worrit is yet???
How about now????
I've had this little project in mind for quite a while, but until now hadn't found a fix. But now I have, and what a success this is. happy3 happy3
The pictures tell the story.This is self coloured 5mm acrylic (perspex) sheet. I tried both red and black to see which looked best.
I'll let you decide......... first the black.....
Then the red.......
I took a lot of care to get the measurements right and had these laser cut and the edges polished. They are such a good fit that you could run with them on the road as dirt barriers were it not for the heat from the brakes (and lack of air flow!!!!!)
They hold in place with (you guessed it) two small pieces of neoprene at 180 degrees on the edge.
And here's the result. I'm so pleased with this........
And that's all for now..........
Time for a cuppa....
E
E
Dave W . Like your solution- a lot! How did you cut the acrylic so neatly? Personally I prefer the Red and would like to do one in silver. Whats your source and cutting solution.
Regards
Ian
DaveW Offline OP
Available laser cut on line - here's an example:
http://www.theplasticman.co.uk/index.php...ASAAEgIX3PD_BwE
E
E
Dave W. Thanks I am on it! What is your wheel size and do to have the ordered Diameters for your disc and internal hole?
Yours looks a perfect fit!
DaveW Offline OP
Unfortunately my measurements are lost in the mists of time. I know that the 4/4 wheels are not the same as the Roadster wheels.
Measure from behind the wheel.
Just take careful measurements. Don't get it too tight or it won't fit. If there's a small gap, it can be held with small neoprene squares. If you need an off-cut of neoprene for this just let me know.
E
E
Followed on from Dave Ws solution to "tart up" my spare wheel.
Really pleased with outcome
Total Cost £28.
Spare Wheel before
Kit of Parts. Silver 5mm perspex disc, Felt disc (to go against wheel hub, Mouse mat foam disc ( to go against wheel mounting bracket anti vibration,5mm "U" section edging strip.
Upside finished
Down side finished
Spare Wheel after
Regards
Ian
Tidy job !!
DaveW Offline OP
Well done Ian!
