9 members (Sir Percival, James B W, John Wilcox, Morganmike, BLUE+4, Jon G4LJW, cerealsurfer, MATTMOG, Graham, G4FUJ), 228 guests, and 49 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
Page 1 of 5 1 2 3 4 5
#489404 17/12/17 05:40 PM
DaveW Offline OP
I've had this issue right from the start on my Roadster. The perspex mists up in the cold garage, and also out on the road in cold weather. Three of the four pieces of perspex do this. The rear offside - in the photo - remains clear. When the sun comes out, or by using a hairdryer, the mist disperses.
We concluded after an earlier post that this is micro water droplets which are being attracted to the perspex, but we don't understand why. The most effective blocker so far has been Autoglym tar remover. This suppresses the misting for a week or two. I haven't given up and will try other products over time.
This is today - a miserable wet day with the temperature hovering around 1 degree C.
Hello DaveW,
I have the same problem, but only one of the four pieces of perspex do this.
Material defect ?
2003 Morgan 4/4 2-seater
DaveW Offline OP
Certainly a material difference Jens. If you look closely there's a coating. but why some mist over and some don't remains a mystery.
Spooky
Is one sheet polycarbonate and one acrylic ?
Have you tried a really gentle 'cutting agent' like the ones for soft top window scratch removal ?
DaveW Offline OP
Yes I've tried all cutting pastes including Meguiars perspex cleaner. The best by far so far is tar remover...........
Rainex? We used to use it on both sides of motorcycle helmet visors.
Could it be possible that the ones that are misting up are put in the inside out? I seem to remember that perspex is "coated" on one side.
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
Take the roof down-problem solved! hide
Gerry
DaveW Offline OP
Rain-ex doesn't work. Visor anti mist doesn't work for long. It mists both sides and is worse with the roof down.
Changing the perspex may be the only cure.
