10 members (Graham, G4FUJ, John V6, RJW, AZJowett, RedThree, Alistair, JMcL, Orjan, Scrambledsignals, Luddite), 97 guests, and 44 robots.
+8Rich 100
John V6 66
Luddite 56
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,576
greenteagod
Page 3 of 3 1 2 3
DaveW Offline OP
You should've known my OCD had it covered.......... innocent
Thanks for this thread Dave. Just finished making my own version. Learnt the hard way that stainless steel is a little tough to drill holes in. Quite pleased with my efforts although not as neat as your version.
Costock, UK
Disco 5
DaveW Offline OP
Post Photobucket Reboot from February 2009:
Today I've been down and dirty once again. Some of you chaps are clearly Trackday Kings, but I'm more of a Sunday Luncher.
Anyway, those who have entered Classic Car runs will know that mounting the Rally Plaque can be bothersome. I've just entered an event in May so thought I would see what could be done.
I figured that a cantilever arrangement could be fitted to the single overrider bolt, mounting the Plaque in front of the wing. It doesn't matter which side, but it won't be interchangeable, so I've gone for the offside.
I dug around for some suitable metal, and came up with a rectangular piece with a small hole at each end which came with the Mog.
I suspect it might be the radio blanking plate because it's about that size.
So after drilling, trial fitting, shaping and painting, it looks like this:
Next I took an old perspex number plate which, when removed from a car had pulled the backing away, leaving a clear piece. I cut this to the right length, filed the raw edge and made two rounded corners to match the other side.
Here's a tip. NEVER throw ANYTHING away.
After marking, this was drilled to fit the red bracket, and fixed with double sided tape and three allen headed stainless bolts with locknuts in proper Mog style. At the unsupported end I've added a rubber buffer to protect the paint.
The next picture shows how easy this is fitted to the Mog.
And here it is in all its glory.
I happened to have an old Rally Plaque from 2007. I use double sided tape to attach 'on the day'. The Devil is in the detail. (Subtle Gag there.........)
As part of my wing protection crusade, I wondered about mounting a small protector in front of the rear wing using the two running board fixings. This should have been straightforward, but the factory (Blessem) had used different sized fixings on each side.
Fortunately the man with the drill had used the same drill, so to retain 'originality' (Hah!!), I used the big fixing on the inside hole and the small fixing on the outer hole.
So eventually I got there:
This one (just) shows the two sized fixings.
DaveW Offline OP
Post Photobucket Reboot from June 2013:
Time to revisit this, and give it a quick refurb, ready for Canterbury. So I stripped it down, and repainted the bracket. I also decided to paint the clear perspex, but because I use double sided tape to secure the rally plaque, it's better painted from behind. I added a black line at the bottom, and then got the idea of adding a large MSCC badge. I can fit the double sided tape on either side of this. I'm quite happy with the result!
DaveW Offline OP
Post Photobusket Reboot from June 2014:
I've had to revisit this again, because red won't match Bumble. So I've restored the bracket - which is a radio blanking plate bent to shape, and the new plastic is black tinted sun visor which was surplus to requirements.
The rally plaque is stuck with double sided tape.
thumbs
Hi Dave, contact Scenic and Classic car tours they sell stick on cups for rally Plaque’s
Series 1 Roadster V6 Silver and red leather......my baby !
DaveW Offline OP
Thanks Andy but I have an aversion to stick on cups........
Page 3 of 3 1 2 3
