2005 car
2 replacement radiators - top pipe joint failure - warranty item
3rd radiator top pipe failure - brazed rather than replaced - probable cause of failures dermot quality mounting bobbins.
Fuel tank leak - aluminium seemed to be porous
Fuel filler hose split
3 front wing bracket failures
3 rear suspension bracket failures
Cracked alternator casing - warranty replacement
2nd cracked alternator casing
3 cracked alternator brackets
Sheared alternator mounting bolt
Fuel pump failure
Split in leather to drivers seat bolster
Hood header rail weld failure
Snapped handbrake cable
Melted fuel pump relay
Rear wheel bearings
Rear brake cylinders
Windscreen washer bottle fell off - rivets no good
Paintwork issues
2 No brake light switch failures
Wiper arm failure
Accelerator cable failure
Speedometer failure - warranty item
Tonneau cover useless - water ponds and runs through zip
Severe ingress of water at driver's door cill - inadequate sealing between chassis and frame
Mirror stems’ chrome pitted
Door handles’ chrome pitted
Script badge pitted.
Without doubt, the most unreliable car I’ve had. It has been on a recovery vehicle eight times, four of which have been in Europe. Very good service from Morgan Rescue. Absolutely no point in calling the factory. Best to keep Colin the Spanner Juggler on speed dial.
