5 members (Chris Cosher, +8Rich, MartO, Barkbark, Montegue), 248 guests, and 60 robots.
+8Rich 62
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,763
#490067 21/12/17 04:44 PM
Just a little miffed to get a letter from DVLA to tell me the VIN recorded by the test station for the last MoT (in June!) of my 17yr old Mog is at odds with their records. I now have to faff about filling in a form stating vehicle reg (front and rear number plates) VIN on the current MoT certificate, VIN on the registration document and VIN on the actual car. Also, make, model and colour of the offending vehicle.
Given its age, this is obviously far from the first test on the car- all others completed without query.
All this admin will have to wait until the new year- in the meantime, where do I find the vehicle VIN?
Gerry
GerryWal #490074 21/12/17 05:00 PM
ask the test station. :-) you might find that they used the alternator part number or simply left the vin from the pervious test they did.
actually, thinking about this, its a bit odd. I thought that they had to have the VIN to find the vehicle on the DVLA database so that it was impossible to input a test with the wrong VIN.
GerryWal #490090 21/12/17 07:26 PM
Try looking on the crossmember in front of the drivers seat, but on a 2000year car it may be elsewhere!
There should also be a plate on the bulkhead.
Look here to get an idea of the range of numbers around year 2000 - D108xxx?
https://fusiontables.google.com/DataSource?snapid=S200232KJ39
GerryWal #490113 21/12/17 09:02 PM
As this issue was niggling me, I decided to get it out of the way.
I found the VIN plate, loose inside the tool compartment under the bonnet. Comparing the documents, I see that the registration document had erroneously substituted '0' for 'D' and the MoT certificate had omitted a '0' altogether. I have sent photocopies of the documents, and plate, back with the required form to DVLA. Just have to securely mount the plate with pop rivets replacing the original adhesive.
Still find it puzzling that, after all these years, it has only just been spotted. doh
Gerry
GerryWal #490190 22/12/17 09:54 AM
Gerry,
What a disappointment. Given the time of year I thought VIN was going to be your drink recommendations for Christmas. Hope you enjoy yourself and don't spend too long in the woods!!! wine
Reg
GerryWal #490196 22/12/17 10:43 AM
Formerly known as Aldermog
Gerry,
probably down to a new computer at DVLA/VOSA that cross checks data.
I was told, by an ex Policeman friend of mine that back in the 1970s there were nearly 100 vehicles registered to 10 Downing Street, London WC1. In some cases with the name of the PM...
Obviously all fraudulent, but he said the only way to check if a car was registered to a false address was to manually review documents.
I suspect that we are now much better at detecting this sort of nonsense.
DaveW #490203 22/12/17 11:46 AM
I had a Moto Guzzi Monza in Australia that had a compliance plate where the VIN had been transcribed from the handwritten entry in the Owners Manual. The handwritten entry had a very badly written 5 where the top bar was out of place making it look like a 3. In effect the plate did not match the frame number though when I re-registered it after the lapse of a couple of years and restoration I did make sure the registration document was correct. I have since sold the bike but I imagine no one has ever noticed the discrepancy as they all work from the registration papers and just check to make sure a compliance plate exists.
GerryWal #490230 22/12/17 02:01 PM
SBM Offline
Gerry,don't worry mate.
If you go down for it I'll bake you a cake with a file in it, how's that?
