1 members (GLLOQ),
209
32
Topics49,897
Posts838,018
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Isn’t there an automatic adjustment mechanism inside the rear brake drum that must be released when reassembling the drum over the shoes?
Posts: 8,698 Likes: 498
Posts: 8,698 Likes: 498 |
Yes, you can see the serrated pawl at around 10 o'clock, just below the lettering Y47 ![[Linked Image]](https://www.tm-img.com/images/2020/04/21/AP-brakes-3.jpg)
Is there a special tool to release it on the car to facilitate drum removal?
BTW, thanks for the photo.
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
No, but you can fit a manual brake adjuster to make the job easier in the future! Check out this THREAD.
Andy
Can't be seen in the photo but externally there should be an oval shaped rubber grommet you can remove, then just pop in a small screwdriver and just ping apart the pawl, it's spring loaded to retract and back off the shoes...job done !
