12 members (Ragnar, +8Rich, JohnHarris, Beard, Ritchie B, Barkbark, Montegue, GrumpyPa, Chiltern MOG, MJF, John V6, TBM), 356 guests, and 91 robots.
+8Rich 78
Topics49,872
Posts837,701
Rudolf
Condor Offline OP
Having read the thread on Morgan quality I consider myself lucky with only around ten problems on my late 2013 4/4. I don’t count the chap that t-boned me in that number, or the issues falling out of that. Of course I still love the Morgan experience- I can’t help it!
My speedo/odo has failed however. The LCD still lights up, but no digits are visible.
Can someone kindly suggest where I start please?
Many thanks for the help I know will be forthcoming and compliments of the season to all.
Oct 13 build 4/4
Hmm. Kind of the opposite of how my dash failed. Quick questions just to check... does the speedo needle still work? Do the heated screen, hazards, and rear fog switches glow when off as per normal? Does the heater fan work still?
I'd check all fuses in the first instance... and not just the ones suggested in the handbook :-)
Cheers
Nick
The fuse that is for the speedo also controls the heater fan and some of the warning lights. If the heater fan is not working you could try the fuse. If that is the problem and it blows again you may have a faulty circuit board.
If it turns out that you have a faulty speedo you will need to send it to Caerbont Automotive Instruments Ltd
Probably a dry joint on the LCD module itself
Mark - No Longer driving
My speedo packed up a couple of times back in the summer and then just started working again, been fine since...Morgan !
Tuftie66
2008 Claret Red +4 Sports
2016 Mazda CX-3, Sport AWD.
Had the same thing happen on my 2011 4/4sport. Turned out it was the wires running under the seat (seatbelt light) got cut when adjusting the seat and shorted out the speedometer
2017 Metallic Black +4 GDI
The display sometimes disappears in damp weather or storage. Run the car with the heater on full for awhile or use a warm hair dryer under the dash. Worth a try!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Ah! I forgot about that. It happened to Raphael (atalante83) in France with his 4/4 Anniversary. The wire had rubbed through the insulation where it entered the transmission tunnel.
Me too ('12 4/4) chafed wire from seatbelt telltale shorted on seat rail and blew fuse - circuit shared with speedometer.
Stuart
For a speedy exit, no doubt.
Best Regards
Lang may yer lum reek
