Posts837,279
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Not forgetting Melvyn Rutter https://mogparts.net/index.php/round-door-mirror-and-arm-to-fit-acr016-mount-stainless-steel.htmlBut this one looks exactly like mine on the car at the moment as isn’t described as convex so I’m going to stay clear of this one as well
Posts: 2,583 |
I have John Taylor convex - brilliant.
I have John Taylor convex - brilliant. Just spoken to John and now ordered
Posts: 149 |
I replaced the standard mirrors with John Taylors convex round ones and the rear view mirror with the large Librands slightly convex one. https://www.librands.co.uk/products-view-69.html Together,they improve all round visibility dramatically. Should be standard safety kit.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I've always got on OK with my "standard" ones. Cannot really change anyway as they wouldn't match the painting lol.
Richard 1976 4/4 4 Seater
I've always got on OK with my "standard" ones. Cannot really change anyway as they wouldn't match the painting lol. I had nothing at all against the traditional oblong ones, in fact I rather like the look as the round ones look a bit lollypoppish (technical term) but I just couldn’t, however hard I tried, get the near side one to adjust to an angle where I could see to reverse into my garage cleanly close against the near side wall It wasn’t the field of vision on the mirror, it was the ball socket and arm I couldn’t adjust correctly
New ones are on and I also had just enough of DaveW’s neoprene gasket to go around the adjuster plate If anyone wants to see the difference in the two mirrors together, I enlisted the help of a handsome model to pose for the camera!! You can see the existing ones on the left are smaller and have a flat field of vision.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I was going to enquire how much neoprene channel you had in stock.......
I was going to enquire how much neoprene channel you had in stock....... Would you believe I had just enough with an inch to spare
I am going to investigate whether the Holden’s replacement 100mm diametre replacement convex mirror replacement will fit into my existing ones
If it does and it works I might swap them back and sell these new ones on
I just hate to make these old ones completely redundant to just sit in a box for ever and a day ready for if I ever sell this Morgan
I’m trying to cut down on unnecessary storing of bits and pieces
