7 members (linklaw, JohnHarris, sewin, Barkbark, Moggo, JMcL, TBM), 76 guests, and 16 robots.
John V6 63
Silicon cf. Silicone
by JMcL - 24/09/26 10:21 AM
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
First Morgan as it is now
by Strathaven, September 15
Topics49,941
Posts838,615
Page 89 of 94 1 2 87 88 89 90 91 93 94
Q8morgan #470118 01/09/17 06:03 PM
So you'll stay in Portugal for another week? That would be really cool! Here's the Motorfestival poster
Caramulo is about 250 kms north from Lisbon, most of them can be done by motorway unless you want to search for some scenic places going north.
Calum will arrive to the mountain thursday (Sep 7th), Gambalunga and myself on friday (Sep 8th). I will be coming from Algarve in the south but most probably will need to stop in Lisbon first so from the 3 participants I will probably be the last to arrive, late evening on friday and head directly for scrutineering.
Check your own agenda and let me know your plans, we'll sort where and when to meet. We are one week away!
2010 Morgan +4
2014 M3W Brooklands
To be raced
Q8morgan #472114 12/09/17 02:38 AM
Q
Q
A question guys about the timing belt. Now that i have the washers between the cover & the engine ..i have noticed some oil, a finger length when i wipe the bottom of the timing belt cover after a days drive. Is that normal?
Q8morgan #472135 12/09/17 07:25 AM
Yes but monitor the situation. If you start to see a pool of oil on garage floor after a long drive, further investigation required. It's usually one of the four camshaft or crank seals weeping.
Q8morgan #472143 12/09/17 08:47 AM
Remove the cover&inspect the cam/crank seals.
If they are dry,oil is almost certainly weeping,in tiny quantities,from the interior,past one of the 2 lower bolts holding the cover in position.
bobo #472189 12/09/17 01:58 PM
Q
Q
Thanks guys..i will remove the cover soon, if the seals are dry. Should i apply some gasket silicone on the lower bolts ?
bobo #472248 12/09/17 06:38 PM
Q
Q
I removed the timing cover & found some white dust, i believe its from the new belt. The 2 lower bolts had oil on them. I added some gasket sealer on the bolt threads & reinstalled everything. That should be it?
Q8morgan #487584 06/12/17 11:29 PM
Q
Q
I Just ordered myself a morgan3wheeler maple wood pen case. It looks very nice.
Ebay item # 202109310448
Q8morgan #492575 06/01/18 03:09 PM
Q
Q
Check out this instagram: takataka514
Some Custom parts added to the body
Q8morgan #492625 06/01/18 06:17 PM
Thats got to be worth 5 mph on the top speed.
Q8morgan #492680 07/01/18 12:50 AM
While no roll bars looks slick, if he ever rolls over he will take 5 off his top as well.
Charlie, Former Editor
