1 members (Julian BB), 305 guests, and 44 robots.
+8Rich 93
Posts837,277
Page 155 of 264 1 2 153 154 155 156 157 263 264
I was meaning to ask you Atalante83, what happened to the front mudguards? Admittedly they are much heavier than they need to be but they do a good job of keeping the road debris out of your eyes and other peoples windscreens. Do you remove your front wheels frequently?
I prefer use it without mudguards
When I go away for A long ride i put them.
Never had any problems.
Do you notice the difference in ride/handling due to the big reduction in un-sprung weight? If you do, then I might consider getting some made up in carbon-fibre (yet sprayed to look stock). Always thought it should make some sort of improvement?
Ringa you might consider a mod to make getting the wheel off easier if you get new mudguards.
I would indeed. Really hoping to hear that the removal of so much weight reaps the expected benefits.
R1NGA, if you remove the mudguards and the steel "radiator" cowl you could be in a lower road tax weight bracket, that would be a benefit wink .
I have A better sight without mudguards And so I find it easier o drive
