7 members (SteveT, simon8201, MartinC, TalkMorgan, riri, Dougie, Tresco),
286
35
Posts837,988
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I want to loose the look of a bright aluminium Mulfab radiator poking down low beneath the car
Can anyone foresee any issues spraying this bit black to loose it visually?
And if this is perfectly doable without problems, what paint would be best?
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Not sure how long it would last, but I'd use VHT exhaust paint. A thin coat should be enough to darken the look, be careful not to clog the fins or you'll mess up the cooling.
Posts: 27,835 Likes: 760
Posts: 27,835 Likes: 760 |
black paint shouldn't hurt provided you don't block the air flow.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Did mine years ago if you dig out a photo on here should be one of the engine (General photo gallery page 2 ) ps. thats in the late 1980s and still going strong . I just give it a coat of wax with the rest of the car . Has not effected anything . Better if you use oil based it does flake in the fins so keep a good quality art brush and a tin of black paint to touch it up . Give Dean a shout . He owes me one as we gave him some home made lemon m/lade with Limoncino liquore Cremoso along with 6 Hot Cross Buns . Last time I saw a look like that was when I give my late Staffy a bone . ps. The lads did not get a sniff.
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
An alternative is to mount a valance. Cain from Wolf engineering produces nice ones. https://www.wolfperformance.co.uk/I fitted a stubby and had it painted in dark blue to match the mog. I am very happy with the result, as well as with the quality of work as well as the service from Wolf engineering. Bert
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 367 Likes: 2
Posts: 367 Likes: 2 |
Sraying it Matt Black would increase it's ability to dispel the heat. Rustoleum produce a very good heat resistant Matt Black paint that is available in an aerosol. If sraying onto aluminium they (Rustoleum) recommend the use of their so called "Sticker" first, which is a primer that greatly improves the adhesion of paint onto difficult surfaces such as aluminium or zinc plated steel.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Anodise the bottom black.
Posts: 1,415 |
Anodise the bottom black. It won’t anodise nicely It will have been welded with 4043 aluminium welding rod which contains silicon The anodising process reacts with the silicon and gives a nasty appearance Paint it with cheap and cheerful satin black spray, scuff up the tank with scotchbrite for better paint adhesion You’ll have no issues with heat rejection, and it’s easy enough to touch up any stone chips Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Thanks everyone for your help
I have had a discussion with Cain on a valance but I’ll do this in the meantime
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Stewart, Make a valance: you are obviously handy and it will protect the bottom of the rad especially if the curve just clears it.
