New
Topics48,365
Posts813,385
Members9,215
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I've followed the thread and the result looks 100%.
I didn't spot why you needed to replace the wings in the first place and who made the fibreglass wings for you and how they did that (from what mould)?
+8 4.8
Posts: 2,403 |
Sid Watson makes the wings - he uses moulds he purchased from David Rutherford when he packed up. http://www.fibreglass-mouldings-cambs.co.uk/He actually has the mouldings for a little known 4/4 competition model the 4/4 Rutherford lightweight. It uses a complete fibreglass moulding for the entire car body and replaces all the body and wooden frame - sitting directly on the chassis. There are a few knocking about and tip the scales at about 550kg.
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
I didn't spot why you needed to replace the wings in the first place The original steel wings were pretty rusty. They were made of 5 individual sections welded together, and to get a smooth surface for painting they were covered in a thin skim of filler. Over the years as the car flexes the filler cracks and water gets in, hence the rust. I wanted to fix the car myself rather than farm out the work, and the prospect of reconstructing the wings with my poor welding skills was unattractive. Replacing the wings seemed the best option. I didn't want to fit steel wings, the modern superform wings won't fit the older cars without modification, and the cost of getting Steve Barnes to make me a set in alloy was prohibitive. Thus I decided to go with the fibreglass option. Sid Watson and his son Matthew are a lovely couple of chaps, very enthusiastic and helpful. It was a real pleasure to get them to make my wings, and an excellent job they made of it too.
Thanks Tim... I think it's a job most of us wouldn't have the plums to begin! It looks a super job and I like the idea of the colour going all the way through the material - no more stone chips showing up!
How did they mould the wings?
+8 4.8
How did they mould the wings? They have a set of moulds, originally made by Dave Rutherford. Basically it's a wooden box containing an inverse wing (ie with the smooth shiny bit on the inside). There's one mould for each wing on a car (ie 4 moulds) and there are 2 sets of moulds, one for the narrow-bodies cars, and one for the wider Plus 8s and later Plus 4s To make the wings, firstly you clean up the surface of the mould and then coat it with a release compound that ensures the new wing won't stick to the mould. Then you apply two layers of neat resin (a two-part epoxy), which provides the smooth outer layer - the so-called 'gel coat'. When you mix up the resin, you can add the appropriate dyes to get the final colour you want. Pieces of woven glass fibre matting are next applied, with the pieces criss-crossing each other to provide a matrix of fibres for strength. The matting is bedded in with more resin, and you keep going until the required thickness is obtained - thin for the race cars to save as much weight as possible, thick (about 6mm) for road cars. Once you're done, the mould is left for a few days for the new wing to cure properly and reach full strength before removing it. Then it's simply a question of trimming the edges of the new wings to match the car onto which they are to be installed, bolting them into position and you're done! I'm sure an experienced Morgan body expert could do it relatively quickly, I reckon I must have spent about 10 hours on each front wing and about 5 hours on each rear.
Posts: 1,943 |
When I built My +8 Bitsa I needed rear wings. Lorne Goldman sent Me His old front wings. I was able to get one rear wing from a Local Friend (new) for $50, but that left Me with one to get. I had a +4 rear wing that I added metal to but that was a bodge. Cuthbert Twillie lent Me Molds for +4 rear wings. It looked like I would be able to modify these molds for a +8. It never got done as I felt the cost/time/uncertainty was too much. So I bought a rear wing from Uncle Mel. Rutter's price was not too prohibitive but the cost of air freight to Seattle was huge. It made Me wish I had spent more time on Glas Rear Wings.
Button
Posts: 1,943 |
When I built My +8 Bitsa I needed rear wings. Lorne Goldman sent Me His old front wings. I was able to get one rear wing from a Local Friend (new) for $50, but that left Me with one to get. I had a +4 rear wing that I added metal to but that was a bodge. Cuthbert Twillie lent Me Molds for +4 rear wings. It looked like I would be able to modify these molds for a +8. It never got done as I felt the cost/time/uncertainty was too much. So I bought a rear wing from Uncle Mel. Rutter's price was not too prohibitive but the cost of air freight to Seattle was huge. It made Me wish I had spent more time on Glas Rear Wings. Just because I have the rear wing molds that Cuthbert Twillie made I got them out as well as a couple of spare (well used) steel ones. It became obvious that much care and craftsmanship must go into these molds if You are going to get the results that Tim got. Not to fault Cuthbert, His project did not require replacing the wings. His project was a bit different. But to get the results that Tim got required molds that were very accurate and rigid. The rear wings are a bit floppy. But magnify the front wings by about a factor of 10, It looks to Me that the wing that was used to make the mold had to be perfect. and then support welded inside the wing to keep it rigid while the mold was made. I have no idea how much Tim paid for those wings. But I bet they were worth every penny (shilling).
Button
Thanks Tim for such detailed replies.... really interesting. Great project and super result.
+8 4.8
Posts: 1,749 Likes: 13
Posts: 1,749 Likes: 13 |
How did they mould the wings? They have a set of moulds, originally made by Dave Rutherford. Basically it's a wooden box containing an inverse wing (ie with the smooth shiny bit on the inside). There's one mould for each wing on a car (ie 4 moulds) and there are 2 sets of moulds, one for the narrow-bodies cars, and one for the wider Plus 8s and later Plus 4s To make the wings, firstly you clean up the surface of the mould and then coat it with a release compound that ensures the new wing won't stick to the mould. Then you apply two layers of neat resin (a two-part epoxy), which provides the smooth outer layer - the so-called 'gel coat'. When you mix up the resin, you can add the appropriate dyes to get the final colour you want. Pieces of woven glass fibre matting are next applied, with the pieces criss-crossing each other to provide a matrix of fibres for strength. The matting is bedded in with more resin, and you keep going until the required thickness is obtained - thin for the race cars to save as much weight as possible, thick (about 6mm) for road cars. Once you're done, the mould is left for a few days for the new wing to cure properly and reach full strength before removing it. Then it's simply a question of trimming the edges of the new wings to match the car onto which they are to be installed, bolting them into position and you're done! I'm sure an experienced Morgan body expert could do it relatively quickly, I reckon I must have spent about 10 hours on each front wing and about 5 hours on each rear. - how many test attempts did they have to get the colour of the gel coat right Tim? I can imagine that ,by the time you allow for the heat as the GF sets and numerous other variables, getting the colour 'spot on' must be a truly 'black art'.... James
Aero8 , Series 1 - Boston Green Mercedes EQC 400 AMG Smart Brabus Convertible Honda Monkey Z125
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
Sid Watson makes the wings - he uses moulds he purchased from David Rutherford when he packed up. http://www.fibreglass-mouldings-cambs.co.uk/He actually has the mouldings for a little known 4/4 competition model the 4/4 Rutherford lightweight. It uses a complete fibreglass moulding for the entire car body and replaces all the body and wooden frame - sitting directly on the chassis. There are a few knocking about and tip the scales at about 550kg. Many years ago i bought one of his lightweights, it even had a light thin gauge chassie. It was a work of art. Tried to use it for autocross racing but the short suspension travel proved unsuitable on grass. Sold it to Allan kennedy who used it for a time as a circuit racer.
