2 members (JoeSpeetjens, Ian B),
267
81
Topics49,867
Posts837,614
Posts: 2,814 |
I use one of these http://www.boot-bag.com/Can get a lot in it and it can double up as a holdall, not had any water ingress even in torrential rain I second that, Boot Bag has loads of room and secures well to rack with plenty of straps.
Gerry
Posts: 12,259 Likes: 318
Posts: 12,259 Likes: 318 |
When I'm away on my own I use a 25litre Peli Storm case. When Jane is with me we need a 75 litre Samsonite hard shell case.
Both are completely waterproof.
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
We started with a large black bin bag as a temporary solution and ended up with a large black bin bag as our permanent solution.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
This is the site for Over Board: http://www.over-board.co.uk/duffels/waterproof-duffel-bags.htmlI would have to look as to whether ours is the 90 or 130 litre, but there are two advantages to these bags. The first is that the end straps secure the bag to the rack. No other fastener is needed, although I tend to use an elasticated spider as a belt & braces. The second is that the bags have a handle on each end, which means that I and MrsW can handle it easily, although it does resemble a body bag.
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
My Mog was supplied with a hood and a tonneau cover. In heavy rain I have used the hood to protect tonneau and driver and the tonneau cover to protect the suitcase.
Posts: 638 |
Thank you everyone - and there was I thinking that options were limited!
Am bound to settle on a solution from this lot.
Cheers
David H
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Uncle Melvyn made a bespoke cover for our antique leather suitcase from the same vinyl material as our hood. Looks really smart and totally waterproof.
Downside is that the suitcase is far to heavy to use and we're considering our options for the upcoming touring season. We also have one of the Morgan leather suitcases and in the end we decided it was impossibly heavy. I looked around and eventually found a suitcase that is reasonably light, looks the part, and has a zip that is almost completely covered. In fact in a light and brief showe I would not even bother to cover it. A clear vinyl cover is available and I use that if it looks like rain. The case is the Brics Bellagio. They are not cheap but they are very, very good. https://www.brics.it/en-gb/catalog/detai...D%3D&icf=20
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
If you want to go down the boot-bag route PM me as I have one for sale!
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
David, I have a suitcase cover that was professionally made for my first 4/4 in black, you are welcome to it if the size is right. I'll have a measure up when I get 5.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I use one of these http://www.boot-bag.com/Can get a lot in it and it can double up as a holdall, not had any water ingress even in torrential rain I second that, Boot Bag has loads of room and secures well to rack with plenty of straps. We use a bootbag and loads of room. It also sits lower on our rack so unimpeded rear view. I use extra straps to fix it but those attached do a good job anyway. The only mod I have done is to add poppers to hold down the flap that covers the zip.
