1 members (Carbuilder),
195
33
Topics49,918
Posts838,254
Posts: 1,947 |
Planenut thanks for that. Could I ask that you put a date on the list & that you highlight any changes or additions in future lists.
Tim
Posts: 1,947 |
Tim
Posts: 2,243 Likes: 73
Posts: 2,243 Likes: 73 |
Good idea Tim, I will do that with the next update. Not been deluged with any more information from others, I cannot have it all surely?
Posts: 655 Likes: 1
WW11 MOG Talk Morgan Regular
Posts: 655 Likes: 1 |
Bloody Brilliant Ian - just what I need for doing my barrel to crankcase gasket replacement
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
Great undertaking Ian. Comparing my own modification list here are a couple of items that could be added to that section on yours. B-G racing steering wheel spacers are available in a variety of depths from Demon Tweaks and likely much cheaper than Morgan dealer sources. Probably only suitable for standard wheel though.  I used a 25mm one. Click above for source. You will then need appropriate longer length M6 button head screws. G56 bonnet fastener ejector spring kit as well. https://www.garage56.co.uk/product/morgan-bonnet-fastener-ejector-spring-kit/Links here for latest parts manual v5.2 in pdf format. https://www.4shared.com/get/H-5MmbB8ei/M3W_Parts_Book_V52.htmlor as individual images which can be used to illustrate a particular issue. You will need to choose page and click on download button on right. https://www.4shared.com/account/home.jsp?sId=fd2cIXcQAf2XAZJg&changedir=hwPJPDi0
Thanks for the details above, I will add it and do another list soon. For info, the Morgan Three Wheeler Club website now has a section for the "5 Speeder", if you click on the "About" tag on the home page it is there. I have put a lot of info on that as well and it is all easily accessible. You don't even have to be a member to access it, although I am sure you all are..... The MTWC is embracing the "5 Speeder" much more now, worth joining if you are not in it.
Posts: 367 Likes: 2
Posts: 367 Likes: 2 |
Hi Ian
You have obviously put a lot of work into this and it is a wealth of useful info. Book marked in my favourites.
Best regards Keith
