0 members (),
306
86
Topics49,849
Posts837,424
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Thinking about downsizing from the +8. What are the experts opinions on the 1800 4/4, how close to a 2 litre duratec are they. Thanks in advance for any info.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
The 1.8 Zetec is (IMHO) a cracking little engine. Of course it is hard to compare with a +8 and does not have the same soundtrack.The 1.8 is surprisingly torquey and willing. It surprises a few larger engined Mogs that try to stay with it! I have not owned a Duratec, though I have driven them. Again, a great engine, with a bit more power and more linear power delivery.
My 1.8 returns around 35mpg average, with 40mpg on a run.
Bud 4/4 "Stanley"
Posts: 402 Likes: 3
Posts: 402 Likes: 3 |
I had a sports exhaust fitted to Merlin (1.8 Zetec) before Christmas and noticed some improvement. Fitted a K&N filter after Christmas and have only been able to take it out for a run a couple of weeks ago. The engine seemed to be very lumpy above 3000rpm on the motorway. Haven’t had chance to check it out again. If it continues I’ll try it out without the K&N again to see if that is causing the issue.
Thoughts anyone?
Tim
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
I loved the1.8 silver top Zetec in my last Mog Much improved with a flowing Librands manifold replacing the heavy cast iron tight cornered one Can’t compare to a trad chassis plus 8 as I’ve never driven one Ray
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi Ray,
Sorry, I haven't driven - +8 so unable to compare to my 70th Anniversary 4/4 1.8 Duratec with sports exhaust.
But, I like this engine and power and torque are more than acceptable. Short shifting is not a problem and pulls OK in higher gears at lowish revs. I'm happy.
My only criticism of the drive train is a notchy gear box until the oil warms up.
Regards
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Ray, I have tried to follow you around the hills in Wales in my Roadster. You +8 is very fast , or maybe the driver is better than me.
You obviously won't have that power in a 4/4. I owned a zetec 4/4 from 1994 & then moved up to a +4, the extra torque made a big difference. The Roadster is simply on another level.
I have had a new 4/4 as a courtesy car also. What I found was compared to the Roadster it was less heavy on the steering & a nice drive but to get rapid performance you had to really work the gearbox.
It is I guess like the difference of a 2 stroke big say an RD350 vs a four stroke like a Honda CB750. Both can go fast but the two stroke needs lots of throttle & gears to get there.
Why don't you hire one for a weekend to see what you think? John
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
Thinking about downsizing from the +8. What are the experts opinions on the 1800 4/4, how close to a 2 litre duratec are they. Thanks in advance for any info. I’m no expert or a particularly fast driver but my 1.8 is more than adequate. It is however a different car now to when I purchased it. The performance was fine but it always felt like the engine could give more and was holding back. A while back I discovered that the throttle bodies on the 1.8 engines had their butterfly movement restricted. I can only assume as an economy measure compared to the 2.0L so I removed the restriction. Now with a remap and sports manifold it is a different car with a lot more get up and go. You may see it in the for sale section before too long
Roger 2011 Plus 4
Posts: 192 Likes: 3
Posts: 192 Likes: 3 |
Hi Roger, did it make a difference removing the butterfly restriction if so is it an easy job. Ian
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Hi Roger, did it make a difference removing the butterfly restriction if so is it an easy job. Ian Roger has one of the relatively rare 1.8 Duratecs. Most 1.8s are either “Silver top” Zetecs or the slightly newer “Black top” Zetecs. There are some excellent companies offering power upgrades, if required.
Bud 4/4 "Stanley"
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
The 1.8 Zetec was often preferred to the 2l by kit builders. They recconed it was a better engine especially for even mild tuning. My last Focus was a 1.8 Duratec and it pulled the car quite well. It would be good in a much lighter car like a Morgan. I tried the smaller and bigger duratec versions and settled on the 1.8. Ray, you know my thoughts on your potential change. All you have to do is overcome the V8 lure! NOT easy as your car goes so well. Think of the long haul re a newer car with less hands on. Once you change over to and settle in on the different driving feel you will be in enjoyment mode. Note...I am just down the road if you need a V8 fix!
