1 members (Ian B),
337
108
Topics49,867
Posts837,614
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Hi Kirk,
It came from me following a chat to Mark Evans at MMC last August.
Paul R and I later did some digging on the Centa website and putting 2 & 2 together beleive that the new rollers are a higher spec rubber and a couple of mm longer. They have a higher heat range - the details are on my PC at woirk so I'll try to dig them out in the week.
Paul's idea is to see how to make getting access to the rollers easier than a full engine out.
Red Leader
Posts: 159 |
Hi Kirk,
Do you know from what build date the updated specification was introduced?
Posts: 1,035 Likes: 36
Posts: 1,035 Likes: 36 |
As mentioned on previous occasions, these couplings are doing something they're not ideally suited for.
They're predominately used in uni-directional loading at steady speeds. In the Morgan they're subjected to load reversals and varying load conditions.
Stop/start driving and hard acceleration/deceleration will shorten the life compared to gentle driving on longer trips.
Running the engine in a narrow rev band may well help, but the attraction of a big V Twin is surely that it can pull from almost nothing.
No, but they were being supplied as spares by Aug 2017. I did however get the impression that it was a relatively new change. I've dug out my research from the Centa site and looking at the spec sheet for some broadly similar looking couplings they have 2 specs for the elastomer (roller) elements. Centalan with a temp spec of -45c – 100C and HD which is -45C – 130C So my assumption is that the original rollers were Centalan and the "new spec" will be HD. Note, this is very much a personal assumption based on a spec sheet for a similar looking coupling and not based on any knowledge or discussion with MMC or Centa
Red Leader
Posts: 1,490 |
. THIS V-Twin can not and should not “pull from almost nothing” regardless of the Centa.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 2,539 |
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
Electric motors and V-16 Cadillac’s pull away from almost nothing. The X-wedge, not so much. My old Moto Guzzi pulled away at low rpms but it had a huge flywheel and was a 90 degree twin.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
Posts: 132 Likes: 1
Posts: 132 Likes: 1 |
That's really interesting research you are doing there GLLOQ Have you been able to measure the temperatures going on with the centa?
PaulR
I made a hole in the crankcase at the last replacement of rubber barrels (October 2015) to provide a ventilation of the crankcase in hot weather, it will perhaps improve the problem of lifetime of rubber, it may extend the duration of life of the rubber, no temperature measurements before and after the assembly of the fan except put your hand on the centa casing which seems to me less warm by putting your hand on the casing after one hour of traffic in slow motion.
