9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff),
298
82
Topics49,858
Posts837,463
Posts: 528 |
Thanks for all the positive responses. I originally posted this in June 17. I reposted because of someone else's post about a Cover.
This response reinforces my idea that we should have a dedicated Forum for Modifications and Inventions so team members get better visibility of each others innovation. I have contacted Simon
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Have just ordered a seat belt buckle for 0.99p delivered from China on Ebay !!!...also doubles up as bottle opener !!! Sounds very useful Kev!
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
A simple budget option (I did use this in real life in my M3W. Works fine!)
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Hannes How do you fix the hook to the tonneau cover? Have you sewn a loop to the underside?
Bud 4/4 "Stanley"
Under tension the hooks hold without loops. I simply „hooked“ them to the edge of the cover. The hooks must have the little plastic tops not to perforate the cover. I used this setup once to prevent flattering and it worked well. The bottom counterpart was luggage on the seat.
Posts: 528 |
My seat belt solution does not work on the M3W because the seat belt fasteners on on the outboard of the seats. I thought for £9 my solution was "budget"! A fastener at 99p from china makes it £7. Each to their own.Plus you cannot open a bottle with a bungee!!  - unless you can tell me different?
Under tension the hooks hold without loops. I simply „hooked“ them to the edge of the cover. The hooks must have the little plastic tops not to perforate the cover. I used this setup once to prevent flattering and it worked well. The bottom counterpart was luggage on the seat. Thanks.
Bud 4/4 "Stanley"
