7 members (JoeSpeetjens, Paul F, Zach, Steve +8, RedThree, Strathaven, JohnHarris),
258
57
Topics49,917
Posts838,230
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
John 1992 plus4 connaught green
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
A pleasant 44 mile potter through the Vale of Belvoir. Only spoiled by the rear view mirror landing on  at one point.
Posts: 37,492 Likes: 994
Posts: 37,492 Likes: 994 |
I hope she didn't crack it  ..
I hope she didn't crack it  .. Not only did she not break it, she also resisted the temptation to rub greasy thumb points on to the face - I will still need to clean it but not quite so much work to do. Under the circumstances, I felt it might be counter productive to offer advice on how she should have caught it!
Posts: 240 |
Managed 90 miles yesterday in the Kent AONB, got utterly lost at one point but wasn't an issue, apart from some of the lanes having a large mound of grass growing down the middle! Did spot another Mog but didn't have time to wave etc, also picked up a small chip on the windscreen
2015 Yellow +4
I hope she didn't crack it  .. Not only did she not break it, she also resisted the temptation to rub greasy thumb points on to the face - I will still need to clean it but not quite so much work to do. Under the circumstances, I felt it might be counter productive to offer advice on how she should have caught it! Glad to hear it's in one piece and you had a nice run out.
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Went for a glorious run today in the Staffordshire sunshine en-route (via a significant detour) to my first ever Morgan MOT I have to admit to being more than a little bit nervous with this MOT being new to Morgans and having done a lot of work in this first year. Rebuilt the front suspension with SSL system and Chrome Kingpins. Fitted a Librands exhaust manifold and system. Fitted a Sifab radiator with mainly new hoses and a new Aluminium Expansion Tank. Sorted out the cooling system by replacing a DIY modified thermostat. Stripped out the Ford ECU and replaced with an OMEX600 including removing the Mass Air Flow Meter (MAF) and most of the Ford wiring. Re-wired the speedo to work directly from a hub mounted pickup instead of the gearbox driven original. Removed and refitted the steering rack, adjusting the free play and fitting a new gaiter. And last but not least, fitted Librands door checks so my wife doesn't ladder any more stockings. With most of these jobs I've had a lot of advice from TM either as answers to direct questions or by delving back into the archives. So thank you TM'ers. The area I was most worried about was the Emissions test having replaced the ECU and removed the MAF but She passed easily with an almost perfect Lambda of 1.005 and very low CO and HC readings. So, my first Morgan MOT passed with flying colours and no advisories. I now think I'm starting to get to know her and the enjoyment just keeps growing.
Bob
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
My annual 240 mile trip to Wolverhampton to collect some special curries and samosas in my P4SS ...roof off all the way...great drive.
Almond Tart
Posts: 12,269 Likes: 324
Posts: 12,269 Likes: 324 |
Posts: 3,643 |
Lovely photos Tim, especially number 1.
