Posts837,952
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I found that Tarka seems to have collected a rash of tar spots on the side of the wings. So, how best to remove them? There are a range of expensive products that claim to do it, but I've also been told that good old WD40 will do the job.
Does anyone have any experience with this problem and what is the collective thought on the best solution?
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
White spirit then re -wax?
1993 T16 +4 Lancia Blue.
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
Posts: 11 Likes: 1
Posts: 11 Likes: 1 |
WD40 or ACF50, allow to soak if patience permits, don't rub hard or far in case there is grit in it!!
John W 2000 4/4 Indigo Blue
Thanks all! WD 40 it is, I'll report back on the result!
Posts: 2,583 |
I use Auto Finesse Oblitarate. Works well on any sticky stuff, tar, etc. Is gentle on paintwork - follow instructions & don`t use in hot sunlight unless you are very careful.
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
I use the Autoglym tar spot remover (when I do it)
Posts: 939 Likes: 21
Posts: 939 Likes: 21 |
Petrol will remove tar spots no problem and wax immediately.
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
I use the Autoglym tar spot remover (when I do it) Me too, tried 'em all and it's the safest product
Posts: 6,538 |
Me too!
Just out of habit !
Neil
