3 members (Gordon D, MartinB60, SteveT), 99 guests, and 42 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
Very true Graham. You do get a better look at the workings.
The easiest way to blank off the oiler system is at the 3-way union on the firewall. Take the two oiler pipes out, remove the olive and the union nut, and bung a ΒΌ" steel ball into the body of the union. Then you can tighten the union nut up and block off the exit.
That way you don't have to strip out the foot button or the feed to the oil pressure gauge.
Ray Offline
Whose got balls that small? innocent
I fitted a pair of tapered brass plugs (from Tim Ayres) to block mine.
Ooh, there's posh!
rofl
Originally Posted By The Impaler
I could never figure out why you would use engine oil to "gease" as the oil would tend to wash the grease out.
I have had no problems.
With Very Kind regards
The Impaler
Phosphor bronce wants oil, not grease. That's why I stick to the original system since 40 years.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
[/quote]
Frank [/quote]
That's why I stick with it on my Plus 8 - if it's good enough for Peter Morgan it's good enough for me. Both my Plus 8's have done well using this system with care.
These remote greasing systems have had a few problems according to posters on here too.
It is essential to get under for a spanner and visual check too so why not do it properly.
Another reason being that I like keeping my cars as original as possible - I don't like badges, spotlights and bits of neoprene and plastic everywhere, I prefer the clean look.
I can't say that the prospect of having 1/4" balls is particularly appealing either grin2.
The Impaler
Frank
Makes Me wonder why MMC abandoned the Oiler as well as damper blades. They must know something. I wonder what? Not used damper blades nor oiler for 15 yers and many, many miles on all 3 of My Morgans. Works for Me. But "Original" is "Original". I hope the air in the tyres are "Original".
Button
As an "originality nut" myself,.... blush
it's Morgan kingpin oiler and damper blades forever Bill. grin2
I did however elect to change out the air in B1800's tire tubes a few years ago, after I detected a slight staleness in it's odor. somestick
Cheers! cheers
Bert & B1800
