7 members (KLASG, nestor59310, Robbie, JMcL, hugo, Vansrv6, RedThree),
179
60
Posts837,946
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Hit them with a Tarpon, the fish oil works a treat..
1993 T16 +4 Lancia Blue.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Angle grinder with 80 grit paper on a pad. VERY quickly removes tar and leaves nice ventilation holes in the panel. Interesting patina. In practise, though, I use Autoglym tar remover. A clay bar can get them off too but elbow grease needed. Wash car, remove tar, rinse, clay, polish, wax. A satisfying couple of hours.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Another user of Autoglym Tar Remover. I used to flounder with tar removal until I came across that product.
Bud 4/4 "Stanley"
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Do you have to use a specific tar remover, or will any multi-porpoise cleaner do?
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
How do you remove olive oil stains from a colour coordinated Polo shirt?
Posts: 37,466 Likes: 988
Posts: 37,466 Likes: 988 |
I use Methylated Spirit and then re polish the area, it works perfectly well and is considerably cheaper. We always have some in the house it's great for cleaning of White goods and removing sticky label deposits and lobsters.
How do you remove olive oil stains from a colour coordinated Polo shirt? If it's already been washed and has gone through a tumble dryer, then sorry to say you're buggered, Dave. The heat will have set the stain permanently. If it hasn't been washed yet, you could try rubbing Vanish or suchlike into it.
How do you remove olive oil stains from a colour coordinated Polo shirt? Burn it unless you are from Yorkshire
Seriously, it needs to be an oil based solvent, MPC.s tend to be water based, some may contain chlorine, or other surfactants, so not advisable.
Reply was to Hamwich...... not Daves shirt
I use Methylated Spirit and then re polish the area, it works perfectly well and is considerably cheaper. We always have some in the house it's great for cleaning of White goods and removing sticky label deposits.
I was once told that undertakers use meths on the hearse to keep the black paint shiny. Not sure how true that is.
