7 members (Graham, G4FUJ, Paul F, dogmog, +8Rich, Mark+4, Themorganeer, Ritchie B), 300 guests, and 40 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,326
Members9,215
#503354 12/03/18 07:43 PM
Lewyth Offline OP
I have a 1996 Plus 4 which refuses to start despite starter motor turning over. It has been suggested that it could be the relay for the immobilser, but I've looked under both side of the bonnet, behind the glove compartment, but can't find. Any suggestions?
Lewyth #503357 12/03/18 07:50 PM
E
E
Have you checked your ignition key.......the immobiliser chip was prone to drop out of the key and therefore the car won't start, try your spare key as well,
Ian
2017 Mercedes Benz SLC 200 AMG.
2019 Mercedes Benz GLA 200 AMG
Now Ex-Mogger!
Lewyth #503360 12/03/18 07:53 PM
Do you have the T16 Rover engine?
Ive found that the TPS (Throttle position sensor) and idle control stepper motor do get rather confused
It does on our year 2000 rover t16 car and Ive found that if you put your foot down a little on the accelerator than turn the starter key she fires up first time.
There is a MEMS piece of software you can run on your phone as an app and have a micro usb to rover mems cable under dash connector to see what the engine 'sees' also shows if you have faulty sensors.
Triumph Herald 1969 13/60
Morris 1970
Lewyth #503376 12/03/18 08:49 PM
My '97 did that to me once.
If you don't normally use the immobiliser, switch it on for a minute (ignition off), then switch off and try again. Mine started. The immobiliser doesn't prevent the starter from turning.
'09 Gen2 MINI Cooper ragtop
Lewyth #503389 13/03/18 01:19 AM
Have you checked for spark and for fuel? Or have you got neither?
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Lewyth #503405 13/03/18 08:22 AM
my 97 +4 did that occasionally and I decided not to use the immobiliser.
Same comment as Graham on getting it to go.
2025 MG ZS EV aka Trigger
exbiker #503413 13/03/18 08:50 AM
Lewyth Offline OP
Many thanks, tried both keys, no joy.
BuyBritish #503414 13/03/18 08:52 AM
Lewyth Offline OP
Thanks Rob, tried the throttle touch, nothing. The rest of your offering a touch to technical for my ageing brain!
Graham, G4FUJ #503415 13/03/18 08:53 AM
Lewyth Offline OP
Thanks Graham, tried that, nothing.
Taffmog #503417 13/03/18 08:59 AM
Lewyth Offline OP
Thanks, as far as I can tell (and my limited knowledge), no sound from the fuel pump. Local service chap believes it to be a relay, but hasn't the time at the moment to come out for a look. He has given me a spare relay and suggested where it should be, i.e left hand side under bonnet towards the bulkhead, but no sign on my model. (I took a look at a later model in the garage and it was very obvious). No obvious indication behind the glove compartment either (another option he said). my motor has the Rover 2 litre engine, if that should make a difference.
