7 members (Strathaven, cerealsurfer, MartinB60, SteveT, Hamwich, tezzer, Graham, G4FUJ),
316
96
Topics49,848
Posts837,399
Posts: 23 |
Under the bonnet on the driver's side, right down at the bottom of the crankcase is an electrical cable attached by one or two bolts (there are different models). Follow the cable up, typically about 9-12 inches long, to a clip fastening (mine is under the throttle linkage but may be different on your T16 engine). Simply press the sides to unfasten the clip then re-insert it. I suggest if you can't find it have a look on the web for a picture of a crankshaft position sensor with the integrated cable it comes with for the T16 then you'll see what it looks like.
Tomorrow'l do
1989 +4 2001 CL500
Posts: 11 |
Thanks, I found a cable/plug roughly where you suggested, pulled it apart then replaced, but unfortunately no success.
Posts: 23 |
Did you get to the bottom of this non-start problem? Just curious in case it ever happens to me again.
Tomorrow'l do
1989 +4 2001 CL500
Posts: 2,290 Likes: 9
Posts: 2,290 Likes: 9 |
Lewith,
Re reading your post. It does sound like the fuel pump relay as you note that there is no sound from the pump. Normally with M16/T16 one turns the key and hears the pump prime before turning to ignition. Are you sure that on your car the relays are not on the inside of the firewall just above the transmission tunnel? In addition look at the Morganatica site (Electrics/relays) which mentions a plus eight but could be relevant.
