0 members (), 222 guests, and 86 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
John V6 #503419 13/03/18 09:01 AM
Lewyth Offline OP
Thanks John. Don't normally use the immobiliser. The problem has arisen since it has been over-wintering in the garage, so I guess it is most probably electrical.
Lewyth #503422 13/03/18 09:22 AM
Have you pressed in the fuel cut off which is on the bulkhead on the passenger's side?
Try also cleaning the contacts on it and the wires to it.
The switch cuts off the pump.
Lewyth #503432 13/03/18 10:42 AM
On the Rover M16 there are two relays on the inside of the firewall above the pedals. Try swapping them over and listen for the fuel pump prime, if it primes but still won't start replace the other relay. T16 may well be similar,
Lewyth #503434 13/03/18 10:49 AM
Have you checked the fuel pump cut-out switch? It is supposed to activate in an impact but can play silly b*****s sometimes.
Lewyth #503442 13/03/18 12:25 PM
I had a problem similar to yours with my M16 1989 +4. Eventually the AA guy tracked the problem to the crankshaft position sensor. He got the car working by removing the connecting clip and simply reclipping it, but advised to get a new one asap which only cost £18 and I fitted it in 10 minutes.
Tomorrow'l do
1989 +4
2001 CL500
John V6 #503449 13/03/18 01:50 PM
Lewyth Offline OP
Thanks, tried that, as best I can. No joy.
meabh #503452 13/03/18 01:52 PM
Lewyth Offline OP
Are they attached to the bulkhead in front of the tool holder?
gsel #503455 13/03/18 01:54 PM
Lewyth Offline OP
Where abouts is that please?
Felix42 #503457 13/03/18 01:57 PM
Lewyth Offline OP
Thanks John, I believe I have, the one on the bulkhead, passenger side. Still nothing.
Lewyth #503471 13/03/18 03:39 PM
Lewyth,
take a cloth and make it completely wet with fuel. close the air inlet completely with the wet cloth. Have someone start while you hold the cloth well. If it starts, the problem is not linked to the fuel supply. If he does not start, the problem is electrical. Then you do not know yet, but you are looking faster in the right direction
stefan
