7 members (jbk, +8Rich, BHV, Morganmike, DaveW, TBM, Montegue), 172 guests, and 56 robots.
+8Rich 79
Luddite 50
Posts837,934
Page 5 of 10 1 2 3 4 5 6 7 9 10
Chris99 #504516 20/03/18 05:20 AM
I put them under the chassis tube because the originals Ones were used by the cowl.
planenut #504554 20/03/18 12:58 PM
Originally Posted By planenut
The P clips don't fit the new leads well Richard. When I took the old leads off I found they were slightly chaffed from the cowl as it gets very close there. I would suggest you cable tie them a bit more outboard to give better clearance. Not driven with them yet either but it seems to start a bit quicker than before from cold.
Thanks Ian but they must have changed the build spec because the P clips I removed were perfect fit for the new 8.5mm cables. I was able to re-use them just adding small washers under the pop rivet heads. No signs of chaffing either so fitted new leads with same run as originals.
Chris99 #504762 22/03/18 12:44 PM
Took the car for a 30+ mile blast yesterday - running great - role on summer.
It started on first churn over, this after standing in cold garage for over six weeks without any battery charging. Those new leads certainly haven't done any harm wink
Chris99 #504812 22/03/18 07:10 PM
Before
Chris99 #504814 22/03/18 07:12 PM
Chris99 #504816 22/03/18 07:14 PM
Chris99 #504817 22/03/18 07:16 PM
Chris99 #504818 22/03/18 07:18 PM
Chris99 #505635 27/03/18 01:21 PM
Anyone have any luck figuring out how to order these in the US? I sent an email but so far nothing back.
2017 M3W Sport Green
Chris99 #505726 27/03/18 08:23 PM
I ordered my Magnecor leads by phone. Always wary of those website enquiry forms.
