1 members (Socalm3w),
263
84
Topics49,873
Posts837,706
Posts: 2,539 |
I looked back. November 31st was the last time out
Posts: 159 |
What the devil? That, Sir, is American rust. Make Malvern Great Again.
Posts: 2,539 |
I do live in what we call "the rust belt"
Posts: 1,075 |
That's common on all of my cars that I've owned in the past many years. My '16 Terrain will do that just overnight if it's raining outside. By the time I back out of my driveway the surface rust is gone. If your rotor is getting surface rust in other places than the pad wear area, you can paint the rotors and that works quite well. Of course do not paint the wear areas.
Dan
Posts: 2,539 |
What sort of paint is good for the rotors?
Posts: 8,684 Likes: 414
Posts: 8,684 Likes: 414 |
Posts: 1,075 |
What sort of paint is good for the rotors? Kirk, here are a few staring places. Do's and Don'ts of painting clipers Eastwood is huge in restoration and other car repair/paint concerns. Eastwood's Caliper Painting Process The bottom line is that probably any hi-temp paint will do the job.
Dan
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Kirk, If you washed the car before you put it away for the winter, there was probably moisture present. Even my Corvette will do that if I wash it an put it away without driving it to heat up the rotors and get rid of moisture
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Surface rust - v common on all cars' disks in the UK!
Posts: 2,539 |
The problem was a winter where several times we had a 40 degree swing in temps in a week. Major condensation.
