1 members (Plus Four Guy),
238
Topics49,915
Posts838,214
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
One of the first mods I do to my occasional use vehicles is to fit a battery disconnect. I had a car 'spontaneous combust' years ago due to a short which occurred while just sitting, and ever since I've been perhaps a little overly cautious.
In any case, I fitted a switch to the M3W which is not all all visible when standing outside the car, but is easily reachable from the drivers seat. The original ground cable was used for one run to the switch, then I made up a new cable to connect to the battery.
I have a couple of photos to post, but have not yet figured a way around the 1kb file limit.
Steve Late 2012 M3W
Posts: 2,539 |
If you host them on flickr its easier
Posts: 12,268 Likes: 324
Posts: 12,268 Likes: 324 |
If you use the TalkMorgan image server at tm-img you won't have any size restrictions. It's free to use (although donations are welcome), carries no advertising, and doesn't share your data with anyone else. Instructions are at https://www.tm-img.com/page/ifu
Tim-thanks for the tip on tm-img.com Photos as referenced in original post:
Steve Late 2012 M3W
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Nice work! On my Caterhams this was always external (maybe something to do with race regs) but this looks neater.
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
My 2013 M3W has a disconnect switch installed. (actually it‘s a removable key) I was not aware this was an extra item.
Posts: 2,539 |
Posts: 1,671 |
Posts: 439 Likes: 3
Posts: 439 Likes: 3 |
Never thought of a disconnect on the ground side - usually it's on the hot side. The advantage is not having to insulate the terminals obviously, and I can't think of any down-side off-hand. Clever approach!
Just be careful to never kill the power with the engine running as you could fry the alternator I believe.
