0 members (),
232
Topics49,918
Posts838,254
Posts: 2,243 Likes: 73
Posts: 2,243 Likes: 73 |
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Lack plug leads from magnecor
They are there, about 3/4 down the engine section, including specification.
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Seems to me this Most Valuable thread would be a sticky topic as it's of value to everyone with a 3W.
Steve Late 2012 M3W
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Planenut another one for your list: Track rod ends comfort kit: Fluro GIXSW14x1.5 Rod End Bearing 14mm Bore M14x1.5 Thread Female Right Hand from ABC bearings.
Posts: 3,735 Likes: 82
Posts: 3,735 Likes: 82 |
Another one for the list - a 3mm x 72mm R clip is an easier to use replacement for the rear axle cotter pin.
Red Leader
Posts: 132 Likes: 1
Posts: 132 Likes: 1 |
And another one.. replacement bolts for the front mudguards in stainless steel SS m8 x 16mm hex head with SS m8 shake proof washers internal serrated type Kays on EBay
PaulR
Thanks for those additions. Next issue will be out soon. Any more information to add gratefully received, don't keep it to yourself.
Posts: 132 Likes: 1
Also... The wooden 'spanner' for 2 eared wheel nuts works well instead of bashing the hell out of them with supplied hammer ...from MWS the wheel supplier
PaulR
A quick one - replace the tyre valve dust caps with ones with a gasket. These will hold pressure if the valve fails EG: https://www.befr.ebay.be/itm/TYRE-ALLOY-...4-/261355892387
Red Leader
