Topics49,909
Posts838,126
Posts: 105 |
Hi everyone A little advice if possible: I've found that I can't get on with the flat glass wing mirrors installed as standard on the S4 (and earlier models no doubt) and I wanted to change them for a convex glass. Is changing the wing mirror glass a fairly sraight forward task or do I need a degree in Ford wing mirrors as installed on Aero 8s?  Thanks David
Posts: 3,727 |
I will probably get jumped and stamped on for this one  . Adhesive overlays?
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
If they fit like VW mirrors there's a simple spring clip and two wires for the heater, but it's mission impossible to get at it. If the mirrors are Ford - consult a Ford dealer..... Or find a gynaecologist Frank's idea is workable if there's sufficient depth to the cowl, and you can locate the correct shape.
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
I have some in bits in the garage, but am in singapore - if nobody else can tell you before the weekend I'll take some pics of them for you...
-------------- Maxxed out!
