Morgan Aero 8
5 members (Clipper, banbury, Luddite, Strathaven, ITP), 245 guests, and 25 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,109
#50870 27/09/10 05:11 PM
David Offline OP
Hi everyone
A little advice if possible: I've found that I can't get on with the flat glass wing mirrors installed as standard on the S4 (and earlier models no doubt) and I wanted to change them for a convex glass. Is changing the wing mirror glass a fairly sraight forward task or do I need a degree in Ford wing mirrors as installed on Aero 8s? confused2
Thanks
David
Green & Grown Up
Green & Grown Up
I will probably get jumped and stamped on for this one hide . Adhesive overlays? idea
If they fit like VW mirrors there's a simple spring clip and two wires for the heater, but it's mission impossible to get at it. If the mirrors are Ford - consult a Ford dealer..... Or find a gynaecologist wink
Frank's idea is workable if there's sufficient depth to the cowl, and you can locate the correct shape.
Mr Fezza
Mr Fezza
I have some in bits in the garage, but am in singapore - if nobody else can tell you before the weekend I'll take some pics of them for you...
Maxxed out!
