Morgan Aero 8
7 members (SteveT, Tony Quinn, Ian Wegg, TeddyAds, GBpluseight, TBM, Grumpy2), 187 guests, and 38 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
#509433 19/04/18 07:03 PM
JB62 Offline OP
On a glorious night like tonight- had to give the Speedster a run. Was challenged a the lights by an enthusiastic gentleman in a Hyundai Coupe. I just bumbled off the line- no point.
Then “ bulb fault” . The near side headlight does not work- the sidelight intermittently. Is this a garage job- or a home fit new unit.
Due to my DIY ineptitude, SWMBO does not allow me a toolset- so should / could I replace?
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
JB62 #509435 19/04/18 07:17 PM
Always worth a quick look, its probably something simple.
Martin (Deano)
JB62 #509438 19/04/18 07:44 PM
SFG Offline
Perhaps you could send your good lady on a mechanic's course?
SFG
2012 4/4 Sport
JB62 #509442 19/04/18 08:11 PM
JB62 Offline OP
Probably need it fixed quicker than that.
Porsche 981 Spyder
JB62 #509443 19/04/18 08:32 PM
I had exactly this issue on the Aeromax.
Long story short, it turned out to be an early symptom of a failing battery. The CANBUS electrics do not like even a small voltage drop before triggering bizarre warning lights and safety cut outs - in my case, not firing up the HT feeds to the HIT headlamp ballasts. New battery fixed it. I also learned that a CTEK charger slowly kills the battery over time, even though apparently keeping it 'fully charged'.
Worth a battery swap to see if it resolves.
Stuart
JB62 #509445 19/04/18 08:38 PM
JB62 Offline OP
Thanks. It’s on a CTEK all the time. Might get the battery tested first?
Porsche 981 Spyder
JB62 #509454 19/04/18 09:55 PM
I'm not sure if your cars have Odyssey batteries fitted?
My S1 Aero does and I recently posted the following comments to a fellow owner when he was having starting problems -
I have also collected a few random opinions/explanations from various people, specifically on the Odyssey batteries and Ctek chargers;see below -
The Odyssey isn’t a gel battery.
It can not be connected on a smart charger over a long period of time on the normal settings.Because of its cranking amps the charger supplies the battery small amps over a long period of time and the Odyssey battery doesn't like this, gets too hot and warps the plates,then expands and cracks and leaks,
The way around this is if you connect your battery (only Odyssey) up to a smart charger is to put the charger on the */Winter setting (3 settings, m/c + car + *). This increases amps and volts and charges quicker and shuts down for longer periods of time, then the battery isn't as hot..
Ctek are aware its only the Odyssey batteries that are affected and have had a lot of reports of battery failure.... Gel types and normal batteries seem to be ok.
As far as I can see from the Ctek manual it pulses when in normal battery maintenance mode where as the Optima charger offers the battery charge in alternate 30 minute periods. The Optima 4, 5 and 6 are recommended for AGM batteries such as Odyssey.
NB on the ctek manual it does recommend using the * cold winter setting for AGM batteries such as Odyssey and Optimate batteries.
The may explain why the Odyssey has a problem with the Ctek on normal battery mode and not with an Optimate charger
I have 'fried' a couple of Odyssey batteries on the Aero by trickle charging (and two on a motorbike - but that's another story....).
I now use the Ctek on the Winter setting and on a timer ;a couple of hours every 2 -3 days
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
JB62 #509524 20/04/18 05:41 PM
uh ... no that's not fair ... not a good enough reason to replace her!
Aero-Ian
Aero 8 Series 1
Defender 90
BMW 330d M Touring
JB62 #509528 20/04/18 06:06 PM
^ rofl
James
Monkey Z125
AeroIan #509530 20/04/18 06:22 PM
JB62 Offline OP
So what circumstances would we consider fair smile?
Anyone know where the battery isolator is on the Speedster ? They showed me when the car was delivered - I was too busy trying to get in and drive to take notice.
Porsche 981 Spyder
