3 members (Robbie, Burgundymog, Sir Percival), 309 guests, and 47 robots.
+8Rich 92
Topics49,837
Posts837,286
Page 4 of 12 1 2 3 4 5 6 11 12
Bitsobrits #509477 20/04/18 08:06 AM
Originally Posted By Bitsobrits
Yes, agreed. The OP mentioned the rollers he chose increased lift, i.e. had an increased ratio over stock (likely 1.60 vs 1.50 which is typical). I was wondering if the increased lift afforded by these particular rockers caused an interference issue.
S & S parts manual quotes roller rocker conversion increases ratio from standard 1.76 to 1.80.
Since all alternative S & S cams are non-interference with standard rockers, including the high performance 618 (0.618" lift) there would be some leeway with lower lift cams.
As an example the 569 cam (next one down in terms of lift and valve duration) would give 0.582" lift with roller conversion so would maintain non-interference.
2Sharp #509552 21/04/18 12:27 AM
2Sharp Offline OP
Really enjoying the cams. Does anyone know what the max RPM is for the X-wedge. Looked around but could not find it.
2017 M3W Sport Green
2Sharp #509553 21/04/18 04:13 AM
The .585 '' springs are for 5750 RPM, the .650 '' are for 6500 RPM
2Sharp #509554 21/04/18 04:19 AM
You need with a map of ECU that allows 6500 rpm
2Sharp #509556 21/04/18 04:34 AM
2Sharp #511013 30/04/18 08:56 PM
Following pictures in the wrong place
after fitting a ring and machining the ring to the correct size
manufacture of an extractor for crankshaft side needle bearings
2Sharp #511020 30/04/18 09:13 PM
Fantastic work, great pictures. us mere mortals would have to buy a new case!! notworthy
2Sharp #511622 03/05/18 07:14 PM
Wanting to put back the reconditioned distribution casing that goes with the polished motor a piece of the cam shaft is to stay in the nut by unscrewing, I had replace the cam shafts last year with the oil pump, the first game replace because a cam shaft was damaged by a needle bearing damage, as I have no left low cam shaft I put a set of camshaft 569, I cross my fingers so that it does not there is more problem before Albert Ball more I still have in stock that trees cam 618 in advance for the engine 132cub in transsexual version, the 569 are not made to make driving grandfather or city on the road it makes you want to titillate the accelerator pedal the tone and engine response is different past 3000 rpm, I hesitated to put back the old rear camshaft of the original rear cylinder which was still in good condition because the engine should be about 90,000 km.
[img]https://zupimages.net/up/18/18/88rg.jpg[/img]
there was a start of worrying traces on the rear exhaust cam shaft from the needle bearing (broken cam shaft), all the material was one year old (can be problem heat treatment?).
2Sharp #512093 07/05/18 07:32 AM
Since I put tree cam stage 2 (569) I lost the engine brake deceleration, it happens to other people with stage 2?.
2Sharp #512159 07/05/18 03:11 PM
I have stage 2 cams (type 569) and it drives like it did formerly except it pulls a lot harder from 3,000 rpms on. Deceleration feels about the same as stock.
