Topics49,844
Posts837,360
Posts: 8,664 Likes: 408
Posts: 8,664 Likes: 408 |
Yes, agreed. The OP mentioned the rollers he chose increased lift, i.e. had an increased ratio over stock (likely 1.60 vs 1.50 which is typical). I was wondering if the increased lift afforded by these particular rockers caused an interference issue. S & S parts manual quotes roller rocker conversion increases ratio from standard 1.76 to 1.80. Since all alternative S & S cams are non-interference with standard rockers, including the high performance 618 (0.618" lift) there would be some leeway with lower lift cams. As an example the 569 cam (next one down in terms of lift and valve duration) would give 0.582" lift with roller conversion so would maintain non-interference.
Posts: 365 |
Really enjoying the cams. Does anyone know what the max RPM is for the X-wedge. Looked around but could not find it.
2017 M3W Sport Green
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
The .585 '' springs are for 5750 RPM, the .650 '' are for 6500 RPM
You need with a map of ECU that allows 6500 rpm
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Fantastic work, great pictures. us mere mortals would have to buy a new case!!
Since I put tree cam stage 2 (569) I lost the engine brake deceleration, it happens to other people with stage 2?.
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
I have stage 2 cams (type 569) and it drives like it did formerly except it pulls a lot harder from 3,000 rpms on. Deceleration feels about the same as stock.
