1 members (jejemek),
223
35
Topics49,844
Posts837,360
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
In mine the "bulb fault" indication comes up randomly, with all lights working properly and disappear in the same way. I noticed that that it happens more often if I have headlights already on when I start the car (but I'm too lazy to turn it on and off manually). So I decided that I can live with the message when it shows up (not more than once after a couple of month) and stays no longer than a few hours.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I get a random bulb failure warning too - normally goes away the next time the car is used.
+8 4.8
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
Used to get random bulb failure warnings on 80s Volvos (just thinking back to several of Dad's 200 Estates).
Posts: 688 |
Near side headlight has failed. Sidelight is intermittent. I think a new unit after I’ve tested the battery.
Porsche 981 Spyder V8 Speedster ( 5 years) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
Posts: 5,587 |
So what circumstances would we consider fair  ? Anyone know where the battery isolator is on the Speedster ? They showed me when the car was delivered - I was too busy trying to get in and drive to take notice. Under RHS bonnet , you will notice a small red button and a black lever in front of the large alloy box , press button to switch off , slide lever anti clockwise to put electrics on.
Posts: 688 |
Posts: 5,587 |
Talking of bulb failure warning light , I've had this and took her in for her service in March and the fault seemed to be a number plate bulb fault confusing the ecu running the beemer systems , its a lot better but sometimes still comes up with the warning on the digital read out , it doesn't take much to mess the beemer ecu .
Posts: 688 |
Just had its MOT and only thing fixed....number plate bulb.
Both headlight and side light gone so it’s off to dealers to have a look. In low bright sun in the evening - in a black car- I need both lights working.
Posts: 688 |
Took it in to RTCC who have confirmed neither a headlight failure or fuse issue So it’s booked in for a fault find.
Put the roof up for the first time. Worked very well.
