Morgan Aero 8
8 members (Ian Wegg, TeddyAds, SteveT, Tony Quinn, GBpluseight, TBM, Grumpy2, Craig Jezz), 197 guests, and 39 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
JB62 #509555 21/04/18 04:31 AM
In mine the "bulb fault" indication comes up randomly, with all lights working properly and disappear in the same way.
I noticed that that it happens more often if I have headlights already on when I start the car (but I'm too lazy to turn it on and off manually).
So I decided that I can live with the message when it shows up (not more than once after a couple of month) and stays no longer than a few hours.
JB62 #509564 21/04/18 06:50 AM
I get a random bulb failure warning too - normally goes away the next time the car is used.
+8 4.8
JB62 #509569 21/04/18 07:27 AM
Used to get random bulb failure warnings on 80s Volvos (just thinking back to several of Dad's 200 Estates).
JB62 Offline OP
Near side headlight has failed. Sidelight is intermittent. I think a new unit after I’ve tested the battery.
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
JB62 #509716 22/04/18 07:15 AM
Originally Posted By JB62
So what circumstances would we consider fair smile?
Anyone know where the battery isolator is on the Speedster ? They showed me when the car was delivered - I was too busy trying to get in and drive to take notice.
Under RHS bonnet , you will notice a small red button and a black lever in front of the large alloy box , press button to switch off , slide lever anti clockwise to put electrics on.
madmax #509784 22/04/18 05:34 PM
JB62 Offline OP
Mad max. Many thanks.
Porsche 981 Spyder
JB62 #509801 22/04/18 06:14 PM
Talking of bulb failure warning light , I've had this and took her in for her service in March and the fault seemed to be a number plate bulb fault confusing the ecu running the beemer systems , its a lot better but sometimes still comes up with the warning on the digital read out , it doesn't take much to mess the beemer ecu .
JB62 #509861 23/04/18 05:29 AM
JB62 Offline OP
Just had its MOT and only thing fixed....number plate bulb.
Both headlight and side light gone so it’s off to dealers to have a look. In low bright sun in the evening - in a black car- I need both lights working.
Porsche 981 Spyder
JB62 #511568 03/05/18 01:26 PM
JB62 Offline OP
Took it in to RTCC who have confirmed neither a headlight failure or fuse issue So it’s booked in for a fault find.
Put the roof up for the first time. Worked very well.
Porsche 981 Spyder
